Datatypes
Wipster
Datatypes
PostPosted: Fri Dec 05, 2008 5:39 am     Reply with quote
Hi
I'm trying to make a data type ITEM which has a variable type, name and pointer to something else but my code errors with;
'Expression must evaluate to a constant' and 'Expecting a declaration' on the first line of initializing.
How can I get around this problem? I'm not experienced with making data types.
I am using PCH Compiler v4.080
typedef struct ITEM_STRUCT
   int8 Type;
   char *Text;
   char *Pntr;
} ITEM;
ITEM Group[] = {
   {0, "TEST", 0},
   {3, 0, 0},
PostPosted: Fri Dec 05, 2008 11:47 am     Reply with quote
I changed the structure element to an array and it compiled.
#include <18F452.H>
#fuses HS,NOWDT,NOPROTECT, PUT, BROWNOUT, NOLVP
   int8 Type;
   char Text[5];
   char *Pntr;
} ITEM;
ITEM Group[2] =
   {0, "TEST", 0},
   {3, "", 0}
andrewg
PostPosted: Sat Dec 06, 2008 12:13 am     Reply with quote
I've done this sort of thing, but I'm pretty sure you need a "const":
const ITEM Group[] = {
Andrew
Wipster
PostPosted: Mon Dec 08, 2008 6:32 am     Reply with quote
Well I did a bit of thinking and with the error 'Expression must evaluate to a constant' I decided to try:
   int8 Type;
   const char *Text;
   const char *Pntr;
} ITEM;
But then it says 'Unknown type' on the first line with the const, could this be a compiler bug?
PostPosted: Mon Dec 08, 2008 1:23 pm     Reply with quote
Here are some threads about using const values in structures:
http://www.ccsinfo.com/forum/viewtopic.php?t=32666
http://www.ccsinfo.com/forum/viewtopic.php?t=32604
http://www.ccsinfo.com/forum/viewtopic.php?t=30610
http://www.ccsinfo.com/forum/viewtopic.php?t=28682
http://www.ccsinfo.com/forum/viewtopic.php?t=22070
Wipster
PostPosted: Wed Dec 10, 2008 7:09 am     Reply with quote
Thanks for linking those threads unfortunately I have already read them, it doesn't look like I can have a pointer to "TEST" because it says it needs to be a constant but you cant have a const pointer because it complains unknown type.
The reason I need pointers is that Pntr should point to another instance of ITEM.
Is there any way around it?
PostPosted: Wed Dec 10, 2008 9:31 am     Reply with quote
I think, the confusion comes from the fact, that C generally allows to use a string constant in assignments in place of a char* pointer. But it's important to understand, that the compiler has to insert a pointer to an implicitely generated string constant.
With CPU's that have different pointer types for data and program memory, as a PIC, it cant' work without copying a rom string constant to data memory before.
The above defined struct ITEM can't hold the string itself, only a pointer, which must be a pointer to data memory (at least in default #device CONST = ROMI mode).
Other pointer options are mentioned in CCS C readme.txt, you can check if they are suitable for your application. A pointer to data memory can only be initialized with the address of a data memory object, or NULL. The below construct compiles without errors.
char ctext1[] = "TEST";
ITEM Group[] = {
   {0, ctext1, 0},
   {3, 0, 0},
PostPosted: Wed Dec 10, 2008 9:33 am     Reply with quote
A whole 'suite' of different solutions, depending on the likely sizes and numbers of the strings involved.
First, store the text message into RAM. Then pointers to these are fine.
Second, don't store a pointer, but store an array index into a larger 'message' array. If (for instance), you make a 20 line constant array, containing the messages, then all that needs to be stored in the structure, is the row numbr containing the required message for the particular item.
Third, if you have a late model compiler, you can have _ROM_ declarations (rather than 'CONST' declarations), that support pointers. You can switch the behaviour of the compiler so const uses this form, but these declarations take more space, and are slower than const declarations, so to my mind it is better to use the separate 'ROM' keyword, and avoid this where it is not needed.
