Dspic configuration fuses
georpo
PostPosted: Wed Nov 19, 2008 4:16 pm     Reply with quote
Can somebody give me an example of a how to use the fuses on a dspic33fj ? For example to make it use internal FRC.
Also do I need to disable any peripherals in order to get IO function on the pins?
georpo
PostPosted: Wed Nov 19, 2008 5:07 pm     Reply with quote
I found it!
The problem is not the fuses. It is the wrong register associations!
Wake UP CCS!!! TRISB = 02C8 and NOT 02C6
I wasted 3 days just to turn on a LED. Idiots!
hockeyjo14
PostPosted: Sun Nov 30, 2008 11:03 am     Reply with quote
Georpo,
I believe I am experiencing the same problem with a dsPIC33F, trying to read PORT B (16 bits). It is always zero even when I measure different with a scope. It sounds like a TRIS B problem.
Where is it that you 'fix' the CCS register associations in the PCD?
Thanks in advance.
