Wrong compiler function if not defining "xmit="? |
Posted: Sat Nov 29, 2008 3:54 am |
Ex1. This will generate right code.
Code: | #use rs232(baud=9600,xmit=PIN_A5,rcv=PIN_A4) |
Ex2. This will generate _wrong_ code!
Code: | #use rs232(baud=9600,rcv=PIN_A4) |
If only using the "xmit" and _not_ the "rcw" there are no problem?
Compiler (PCH) V_4.074 |
Posted: Sat Nov 29, 2008 4:00 am |
This is completely normal.
_If_ you only select one pin, the compiler will assume you deliberately want to use a _software_ UART, and generate the code for this.
Do a search here. I have posted in the past, how to turn off half the UART, if you only want to use one hardware pin.
Posted: Sat Nov 29, 2008 8:21 am |
Hi
If looking at the generated code, i think it,s wrong!
Code: | 0050: BSF STATUS.RP0
0051: BCF TRISIO.TRISIO0
0052: BCF STATUS.RP0
0053: BCF GPIO.GP0 <----This will clear GP0 and it's not defined???
0054: MOVLW 08
0055: MOVWF @21
0056: GOTO 057
But the workaround is define both pin and only use one, thanks. |
Posted: Sat Nov 29, 2008 8:46 am |
Problem is I see no suggestion that this is the generated code for the RS232 line...
You need to give us something to work on:
1) What processor.
2) A_minimum_ compilable program that shows the fault. Normally just the processor include, fuses, clock settings, RS232 declaration, and a couple of lines, showing some serial I/O, to show where this code is actually being generated.
You say the compiler is PCH, but the code shown, looks to be PCM code.
