initializing const array of structs
kender
PostPosted: Wed May 23, 2012 5:53 pm     Reply with quote
I want to have an array of structs. It would be nice if I could make it a const, but that not required. I think the following initialization should work. At least it compiles.
struct
  unsigned char c;
  unsigned int8 iSegmentCode;
NON_NUMERIC_SEGMENT_MAP[]
  = { {'-', 0x40}, {' ', 0x00}, {'E', 0x79} };
But for some reason, this code doesn’t work. It doesn’t evaluate to true where it should
if (NON_NUMERIC_SEGMENT_MAP[j].c == acChars[i])
Can anyone spot a problem?
Any suggestion, insight or reference is really appreciated!
- Nick
PIC18F4221
4.081
Read the label, before opening a can of worms.
PostPosted: Wed May 23, 2012 10:31 pm     Reply with quote
We can almost certainly give you an answer, but it would be helpful if
you would post a small compilable test program that shows the problem.
