PIC16F88 cannot read RS232
PICman
PostPosted: Mon Dec 01, 2008 4:20 pm     Reply with quote
Hi...
I have a problem with a PIC16F88 and the #int_RDA interrupt.
I configured the PIC for 9600,8,N and while I can send (without any
problem) data out from the microcontroller, I have no reaction from it
when I send RS232 data into it.
My code:
//               PIC16F88
// RA3 = RXD
// RA1 = TXD
//                     _________  _________
//                  __|         \/         |__
//  DEL debug      |__|Ra2          41  Ra1|__| 9600 bps --->---
//                  __|                    |__
// --->-- 9600 bps |__|Ra3          40  Ra0|__|
//                  __|                    |__
//                 |__|Ra4            clkin|__| 11,0592 MHz in
//                  __|____                |__
//              +5V|__|MCLR/Vpp      clkout|__|
//                  __|                    |__
//               0V|__|Vss              Vdd|__| +5V
//                  __|                    |__
//                 |__|Rb0/int  Rb7/ICSPDAT|__|
//                  __|                    |__
//                 |__|Rb1          Rb6/PGC|__|
//                  __|                    |__
//                 |__|Rb2              Rb5|__|
//                  __|                    |__
//                 |__|Rb3              Rb4|__|
//                    |____________________|
#include <16F88.h>
#device adc=8
//#FUSES XT,NOWDT,PUT,NOPROTECT,BROWNOUT,NOMCLR,NOLVP,NOCPD
//#use fast_io(b)  //On ne veut pas barrer le TRIS (port I2C)
#FUSES EC_IO,NOWDT,PUT,NOPROTECT,BROWNOUT,NOMCLR,NOLVP,NOCPD
#FUSES
#use delay(clock=11059200,RESTART_WDT)
#use rs232(baud=9600,parity=N,xmit=PIN_A1,rcv=PIN_A3,bits=8)
  //no master clear a5 (reset) ;cpd barrer eedata;nolvp lo-volt prog
void entree_rs232(void);               //
void rad(void);                        //
void aff_stream(int8);                 //
void ini_pic(void);                    // P R O T O T Y P E S
int1 a_0,a_1,a_2,a_3,a_4,a_5,a_6,a_7;  //
int1 carac_entre;                      //
int8 carac;                            //
int8 message;                          //
//#ZERO_RAM
//#int_RTCC
#int_RDA              //
void RDA_isr(void)    //
{                     // The (in)famous interrupt that does NOT
   carac=getc();      // work!
   carac_entre=1;     //
void ini_pic(void)                                       //
   setup_adc_ports(NO_ANALOGS|VSS_VDD);                  //
   setup_adc(ADC_OFF);                                   //
   setup_spi(FALSE);                                     //
   setup_timer_0(RTCC_INTERNAL|RTCC_DIV_1);              //
   setup_timer_1(T1_DISABLED);                           //
   setup_timer_2(T2_DISABLED,0,1);                       //
   setup_comparator(NC_NC_NC_NC);                        //
   setup_vref(FALSE);                                    //
   enable_interrupts(INT_RDA);                           //
   enable_interrupts(GLOBAL);                            //
   setup_oscillator(False);                              //
   port_b_pullups(true);                                 //
   output_a(0);                                          //
   output_b(0);                                          //
   set_tris_a(0b11111001);  // gauche=bit7, droite=bit0  //
   set_tris_b(0b11111111);  // gauche=bit7, droite=bit0  //
void aff_stream(int8 message)                                                //
   putchar(65);                                                              //
   delay_us(104);  // To add a second stop bit                               //
   putchar(66);                                                              //
   delay_us(104);                                                            //
   putchar(67);                                                              //
   delay_us(104);                                                            //
   putchar(68);                                                              //
   delay_us(104);                                                            //
   putchar(69);                                                              //
   delay_us(104);                                                            //
   if(message==0)                                                            //
      putchar(48);                                                           //
      delay_us(104);                                                         //
   if(message==1)                                                            //
      putchar(49);                                                           //
      delay_us(104);                                                         //
void main()                                                             /////
   ini_pic();                                                           /////
   a_0=1; //                                                            /////
   a_1=1; //                                                            /////
   a_2=1; //                                                            /////
   a_3=1; // pour éviter l'envoi de chaînes                             /////
   a_4=1; // à la mise en marche.                                       /////
   a_5=1; //                                                            /////
   a_6=1; //                                                            /////
   a_7=1; //                                                            /////
   carac_entre=1;                                                       /////
   putchar(0xFF); // Pour initialiser la ligne RS232 à MARK             /////
   while(1)                    //                                       /////
      if(input_state(PIN_B0))  //                                       /////
         if(a_0==0)            //                                       /////
         {                     // Character stream is sent              /////
            aff_stream(0);     // on LO-HI transition                   /////
            a_0=1;             //                                       /////
      else                     //                                       /////
         a_0=0;                //                                       /////
         delay_ms(100);        //                                       /////
      if(carac_entre)            //                                     /////
         delay_ms(50);           // Make the LED on pin 1 flash         /////
         output_high(PIN_A2);    // on #int_RDA                         /////
         delay_ms(50);           //                                     /////
         output_low(PIN_A2);     //                                     /////
         output_high(PIN_A2);    //                                     /////
         carac_entre=0;          //                                     /////
I checked everything I could see. The crystal is a 11.0592 MHz (9600 * 1152) and I get my data out at a precise frequency (9600 +/- 10 bps) despite my raw way to add a second stop bit! I checked my interrupts (GLOBAL and #int_RDA), I've read the info. about #int_RDA in the manual and tested with both CCS 4.074 and 3.249.
My test circuit does (is supposed to...) flash an LED on pin 1 when an RS232 character is sent to the PIC. I've checked the waveform on pin 2 (RS232 input) and it's okay (idle at MARK (+5V) and levels ok, BTW, it's fed by a MAX232). I also changed the RS232 input pin (along with it's TRIS) w/o any success.
Did anyone ever get that problem ? and how did you solve it ?
Thanks for your attention.
PostPosted: Mon Dec 01, 2008 4:34 pm     Reply with quote
#int_RDA
void RDA_isr(void)
{ // The (in)famous interrupt that does NOT work!
carac=getc();
carac_entre=1;
#int_rda only works with the hardware UART. To use #int_rda, change
your #use rs232() statement to use pins B5 and B2 for Tx and Rx.
Also change your hardware connections to use those pins.
PICman
PostPosted: Mon Dec 01, 2008 9:38 pm     Reply with quote
Wow!
Thanks a lot !!!!
I'll try that tomorrow ! That completely make sense !
Again, thanks !
PostPosted: Tue Dec 02, 2008 7:36 am     Reply with quote
IT WORKED !
I just tried it and everything's okay !
Thanks PCM Programmer !
