3-wire SPI device and 4-wire SPI device on the same bus?
PostPosted: Tue Nov 25, 2008 12:48 pm     Reply with quote
Hi all,
I'd like to use a 3-wire SPI device (Omron B6TS-08 capacitive sensor) and a 4-wire SPI device (MRF24J40 Zigbee) on the same SPI bus. (pic 18F6627)
Omron B6TS-08, 3-wire: SD (data I/O), SCLK and CS.
MRF24J40, 4-wire: SDI, SDO, SCLK, CS.
Is there any problem about this and can someone share experience about hardware and software with a case like this?
How to configure SPI in this case?
thank you.
Best regards,
Franck
RLScott
Re: 3-wire SPI device and 4-wire SPI device on the same bus?
PostPosted: Tue Nov 25, 2008 2:23 pm     Reply with quote
You can do it by adding one resistor between the PIC's SDI and SDO. The size of the resistor depends on what speed you need. Connect the Omron's SD pin to the PIC's SDI pin.
When you are talking with the Zigbee, the Omron is out of the picture. The resistor between SDI and SDO must be large enough that the Zigbee can drive SDI and the PIC can drive SDO and neither will affect the logic level of the other.
When you are talking with the Omron, the PIC drives SD through the resistor. The resistor in combination with the stray capacitance on the SD line adds to the logic level settling time, so you might need to avoid the fastest SPI speeds. Then when the Omron decides to drive the SD line, it can overpower the resistor just like the Zigbee did.
So your design criteria for the resistor is that it must be high enough so that the Zigbee and the Omron can override it, and low enough to keep up with the selected SPI speed.
Robert Scott
Real-Time Specialties
Embedded Systems Consulting
Fram_fr
PostPosted: Tue Nov 25, 2008 4:21 pm     Reply with quote
Robert,
Thank you for your feed-back, I keep in mind your solution and will finish my hardware design. I'll let you know the result in some weeks.
regards,
Franck
treitmey
PostPosted: Tue Nov 25, 2008 5:19 pm     Reply with quote
http://ww1.microchip.com/downloads/en/DeviceDoc/39776b.pdf
see note page 10 by
2.13 Serial Peripheral Interface (SPI)
Port Pins
It is references a tri-stated inverter NC7S7125PSX from
Section 4.4 “MRF24J40 Schematic and
Bill of Materials”
