robinaspey
Joined: 01 Oct 2008 Posts: 4 Location: England (for time being)
16F877 Problem - passing string data |
Posted: Tue Nov 25, 2008 7:28 am |
I'm having a problem with sending some sample data to test a microcontroller - the data is passed via a 16F877 and the
character strings dont get passed from the sample data array.
Here is the code.
Code: | /***********************************/
/* PROGRAM SIMULATE STREAM */
#include <16F877.h>
#device ICD=TRUE
#device PASS_STRINGS=IN_RAM
#fuses HS, NOWDT, BROWNOUT, NOPROTECT, PUT
#use delay(clock=20000000)
#use rs232(BAUD=9600, XMIT=PIN_C6, RCV=PIN_C7, STREAM=SIMOUT, ERRORS)
#define RED_LED PIN_D0
// Placing strings in ROM
#define MAXDATA 23
typedef unsigned int UINT8 ;
// Heres the test data
const char *sdata[]= { "00:24:35 0980200,",
"00:24:37 0980000,",
"00:24:53 0980000,",
"555555 ,",
"00:26:16 0980200,",
"00:27:16 0980200,",
"00:28:16 0980200,",
"4523 ,",
"00:29:28 0980380,",
"00:30:28 0980200,",
"00:31:28 0980200,",
"00:32:28 0980200,"
"00:33:28 0980200,",
"00:34:28 0980200,",
"00:35:28 0980200,",
"00:36:28 0980200,",
"00:37:28 0980200,",
"00:38:28 0980200,",
"00:39:28 0980200,",
"00:40:28 0980300,",
"00:41:28 0980300,",
"00:42:28 0980200,",
"00:43:28 0980200," };
UINT8 counter = 0;
fprintf(SIMOUT, "\r\nSTARTING TELEMETRY SIM.\r\n");
fprintf(SIMOUT, "Sending test data in 1 second ..........\r\n");
while(TRUE) {
fprintf(SIMOUT, "String: %s", sdata[counter++]);
delay_ms(600);
if (counter >= 22) counter = 0;
output_toggle(RED_LED);
_________________ Thanks in advance ... |
Posted: Tue Nov 25, 2008 2:12 pm |
In the 16F PICs (with the PCM compiler), there is a limit of 256 bytes
per 'const' array. If you break up the array into two pieces, then it
works. Example:
Code: | #include <16F877.h>
#device *=16
#use rs232(BAUD=9600, XMIT=PIN_C6, RCV=PIN_C7, ERRORS)
char const sdata_1[14][18]=
"555555 ," ,
"4523 ,",
"00:32:28 0980200,",
"00:34:28 0980200,"
char const sdata_2[9][18]=
"00:43:28 0980200,"
int8 i;
printf("Start\n\r");
for(i = 0; i < 14; i++)
printf("%s\n\r", sdata_1[i]);
for(i = 0; i < 9; i++)
printf("%s\n\r", sdata_2[i]);
