16F877 Problem - passing string data
robinaspey
PostPosted: Tue Nov 25, 2008 7:28 am     Reply with quote
I'm having a problem with sending some sample data to test a microcontroller - the data is passed via a 16F877 and the
character strings dont get passed from the sample data array.
Here is the code.
/* PROGRAM    SIMULATE STREAM        */
#include    <16F877.h>
#device    ICD=TRUE
#device   PASS_STRINGS=IN_RAM
#fuses      HS, NOWDT, BROWNOUT, NOPROTECT, PUT
#use    delay(clock=20000000)
#use    rs232(BAUD=9600, XMIT=PIN_C6, RCV=PIN_C7, STREAM=SIMOUT, ERRORS)
#define RED_LED      PIN_D0
// Placing strings in ROM
#define   MAXDATA      23
typedef   unsigned int UINT8   ;
// Heres the test data
const char *sdata[]=  {      "00:24:35 0980200,",
                  "00:24:37 0980000,",
                  "00:24:53 0980000,",
                  "555555  ,",
                  "00:26:16 0980200,",
                  "00:27:16 0980200,",
                  "00:28:16 0980200,",
                  "4523    ,",
                  "00:29:28 0980380,",
                  "00:30:28 0980200,",
                  "00:31:28 0980200,",
                  "00:32:28 0980200,"
                  "00:33:28 0980200,",
                  "00:34:28 0980200,",
                  "00:35:28 0980200,",
                  "00:36:28 0980200,",
                  "00:37:28 0980200,",
                  "00:38:28 0980200,",
                  "00:39:28 0980200,",
                  "00:40:28 0980300,",
                  "00:41:28 0980300,",
                  "00:42:28 0980200,",
                  "00:43:28 0980200,"    };
UINT8 counter = 0;
fprintf(SIMOUT, "\r\nSTARTING TELEMETRY SIM.\r\n");
fprintf(SIMOUT, "Sending test data in 1 second ..........\r\n");
while(TRUE)   {
   fprintf(SIMOUT, "String: %s", sdata[counter++]);
   delay_ms(600);
   if (counter >= 22) counter = 0;
   output_toggle(RED_LED);
Thanks in advance ...
PostPosted: Tue Nov 25, 2008 2:12 pm     Reply with quote
In the 16F PICs (with the PCM compiler), there is a limit of 256 bytes
per 'const' array. If you break up the array into two pieces, then it
works. Example:
#include <16F877.h>
#device *=16
#use rs232(BAUD=9600, XMIT=PIN_C6, RCV=PIN_C7, ERRORS)
char const sdata_1[14][18]=
                  "555555          ,"  ,
                  "4523            ,",
                  "00:32:28 0980200,",
                  "00:34:28 0980200,"
char const sdata_2[9][18]=
                  "00:43:28 0980200,"
int8 i;
printf("Start\n\r");
for(i = 0; i < 14; i++)
    printf("%s\n\r", sdata_1[i]);
for(i = 0; i < 9; i++)
    printf("%s\n\r", sdata_2[i]);
