CAN RX isn't working...short code example posted
seidleroni
PostPosted: Fri Nov 21, 2008 1:50 pm     Reply with quote
I am using the short code below, but the CAN receive interrupts aren't getting triggered (and neither is the can_kbhit). The printf's don't output anything, and the LED on PIN_A4 isn't toggling when I send the PIC a CAN message (although it does toggle every second according to the code). I know that CAN is working because I'm receiving CAN messages FROM the PIC, AND I know that my messages going TO the PIC are getting acknowledged because my PC program doesn't show any errors when I send the PIC the command. Any questions why I'm getting no "action" when the PIC is receiving a CAN packet?
Here's the code... (I'm using compiler version 4.081)
#include <18F4685.h>
#include <math.h>
#include <stdlib.h>
#include <string.h>
#include <ctype.h>
#include <can-18xxx8.c>
#FUSES H4
#use delay (clock=40M, oscillator=10M)
#USE RS232(Baud=19200, XMIT=PIN_B6, RCV=PIN_B7, BITS=8, PARITY=N, ERRORS)
#int_CANRX1
CANRX1_isr()
   output_bit(PIN_A4, !input(PIN_A4));
   printf("1");
#int_CANRX0
CANRX0_isr()
   printf("0");
void canSetBaud(void)
   can_set_mode(CAN_OP_CONFIG);
   BRGCON1.brp       = 7;
   BRGCON1.sjw       = 0;
   BRGCON2.prseg    = 2;
   BRGCON2.seg1ph   = 7;
   BRGCON2.sam      = 0;
   BRGCON2.seg2phts = TRUE;
   BRGCON3.seg2ph   = 7;
   BRGCON3.wakfil   = FALSE;
   RXB0CON.rxb0dben=FALSE;
   can_set_mode(CAN_OP_NORMAL);
   int buffer[8], rx_len;
   int32 id = 0xAFAFAFAF;
   setup_adc_ports(AN0|VSS_VDD);
   setup_adc(ADC_CLOCK_INTERNAL|ADC_TAD_MUL_0);
   setup_psp(PSP_DISABLED);
   setup_spi(FALSE);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   enable_interrupts(INT_CANRX1);
   enable_interrupts(INT_CANRX0);
   buffer[0] = 0x00;
   buffer[1] = 0x11;
   buffer[2] = 0x22;
   buffer[3] = 0x33;
   buffer[4] = 0x44;
   buffer[5] = 0x55;
   buffer[6] = 0x66;
   buffer[7] = 0x77;
   can_init();
   canSetBaud();
   //set_adc_channel(0);
   while (TRUE)
      if (can_kbhit())
      can_putd(id,buffer,8,3,TRUE,FALSE);
PostPosted: Fri Nov 21, 2008 3:50 pm     Reply with quote
Read both pages of this thread.
http://www.ccsinfo.com/forum/viewtopic.php?t=26637
seidleroni
PostPosted: Mon Nov 24, 2008 8:14 am     Reply with quote
I found the problem. my canSetBaud function needs to have one more line in, and then the final function will look like this:
   BRGCON1.brp       = 7;
   BRGCON1.sjw       = 0;
   BRGCON2.prseg    = 2;
   BRGCON2.seg1ph   = 7;
   BRGCON2.sam      = 0;
   BRGCON3.seg2ph   = 7;
   RXB0CON.rxm      = CAN_RX_ALL;  //added line to make receive interrupts work
