bfoster Guest
| Problem with 'fast_io" |
Posted: Sat Nov 22, 2008 10:08 am |
I am having a problem using the fast_io directive. I am trying to blink two LEDs, one on A0 and the other on A1. When I '#use standard_io(all)', everything works great. When I '#use fast_io(all)' and include ' set_tris_a(0xC0) in the Do...While loop in Main, the outputs don't toggle.
I am working with a 16F871 with Compiler version 4.082.
Any suggestions would be greatly appreciated!!
Thanks,
#include "C:\Test Project\main.h"
#use rtos(timer=0,minor_cycle=100us)
//#use fast_io(all)
byte Blinker,BlinkOut;
byte Blinker1,BlinkOut1;
#task(rate=100us,max=100us)
void Handler();
#task(rate=250ms,max=100us)
void Blink();
void Blink() {
++Blinker;
BlinkOut = Blinker & 0x01;
If (BlinkOut == 0)
Output_Bit(Pin_A0,0);
Output_Bit(Pin_A0,1);
void Handler () {
++Blinker1;
BlinkOut1 = Blinker1 & 0x01;
If (BlinkOut1 == 0)
Output_Bit(Pin_A1,0);
Output_Bit(Pin_A1,1);
setup_adc_ports(NO_ANALOGS);
setup_adc(ADC_OFF);
setup_psp(PSP_DISABLED);
setup_timer_1(T1_DISABLED);
// TODO: USER CODE!!
rtos_run();
do {
// set_tris_a(0xC0);
}while (1);
RLScott
| Re: Problem with 'fast_io" |
Posted: Sat Nov 22, 2008 12:53 pm |
Just a guess, but I think that when you call rtos_run() in the main program, the main program is suspended until the rtos shuts down. Therefore your set_tris_a is never executed. Call set_tris_a just once before calling rtos_run().
As for getting rid of your e-mail, you can do that yourself. Just click on "Profile" at the top the page and edit your own profile. Uncheck the box that says "Always show e-mail address.". If that doesn't work retroactively, then just delete the first posting entirely. Do that by clicking on the "X" on the right of the posting. _________________ Robert Scott
Real-Time Specialties
Embedded Systems Consulting |
