ask to source code PWM
many
PostPosted: Wed Nov 19, 2008 12:14 pm     Reply with quote
Hello
I need to use the output pin C1 -2 in PWM mode of the micro PIC16F877.
And, I use two switch control, by each switch need to ouput PWM 3 signal (or 3 duty cycle).
For the use control DC motor
Anyone can help me please ?
Thanks you very much.
PostPosted: Wed Nov 19, 2008 1:08 pm     Reply with quote
See the sample code in this post:
http://www.ccsinfo.com/forum/viewtopic.php?t=17729&start=1
many
ask to souce code PWM
PostPosted: Thu Nov 20, 2008 12:59 pm     Reply with quote
I'm sorry to disturb
I want use to the source code concern the switch use control output PWM 3 value each one switch.
Because I write program don't working.
help me please.
Thank you very much.
