PIC24HJ64GP502 NVMKEY address
khtang
PostPosted: Sat Nov 15, 2008 9:25 pm     Reply with quote
I am working on PIC24HJ64GP502 and checked my ..\MPLAB IDE\Device\ directory for the *.dev files. Apparently in the PIC24HJ64GPx02.dev files the special function registers have different address from what the datasheet indicated:
sfr (key=NVMCON addr=0x762 size=2 access='rs rw rw u u u u u u rw u u rw rw rw rw')
sfr (key=NVMKEY addr=0x768 size=2 access='u u u u u u u u w w w w w w w w')
sfr (key=PMD1 addr=0x772 size=2 access='rw rw rw rw rw rw rw rw rw rw rw rw rw u rw rw')
sfr (key=PMD2 addr=0x774 size=2 access='rw rw u u u u rw rw u u u u rw rw rw rw')
sfr (key=PMD3 addr=0x776 size=2 access='u u u u u rw rw rw u u u u u u rw u')
From the datasheet, for instance, NVMKEY should be located at 0x766 instead of 0x768. Looking through other device files of the same family, they are all pointing to address 0x766.
I just want to confirm that the device files are wrong and the datasheet is correct. Please verify for me, thanks.
PostPosted: Sat Nov 15, 2008 11:43 pm     Reply with quote
If you have a question about MPLAB files, you should ask it in one of
the Microchip forums, not the CCS forum. Here's the link:
http://forum.microchip.com/
You want this section:
[16 bit Microcontrollers & Digital Signal controllers]
or maybe this section:
[Development Tools]
