Incompatibility between HID bootloader and CCS USB routines
philippe320
PostPosted: Fri Nov 14, 2008 10:51 am     Reply with quote
Hello everybody,
Here is my code :
//set to 1 to use a PIC's internal USB Peripheral
//set to 0 to use a National USBN960x peripheral
#define __USB_PIC_PERIF__ 1
#if !defined(__PCH__)
 #error USB CDC Library requires PIC18
#endif
#include <18F2550.h>
#build(reset=0x1000)
#build(interrupt=0x1008)
#org 0,0x0FFF void bootloader() {} // nothing will replace the bootloader memory space
#fuses USBDIV,PLL5,CPUDIV2,HSPLL
#fuses NOIESO,NOFCMEN,NOWRT
#fuses VREGEN,BORV20,NOBROWNOUT,NOPUT
#fuses NOWDT,WDT32768,CCP2C1
#fuses NOPBADEN,NOLPT1OSC,MCLR
#fuses NODEBUG,STVREN,NOLVP,NOXINST
#use delay(clock=48000000)
#include <usb_cdc.h>
void Init_PIC();
void Blinking();
// Configure the demonstration I/O
#define LED_ON       output_high
#define LED_OFF      output_low
#define LED_TOGGLE   output_toggle
#define TSOP         PIN_B7
#define LED_bleue    PIN_B6
//___________________________________________________
void main(void) {
Init_PIC();
// 2 blinkings;
Blinking();
Blinking();
while (TRUE) {
      if (!input(TSOP)) LED_ON(LED_bleue);
      else LED_OFF(LED_bleue);
 } //while
} //main
void Init_PIC() {
LED_OFF(LED_bleue);
} //proc
void Blinking() {
LED_ON(LED_bleue);
LED_OFF(LED_bleue);
delay_ms(900);
} //proc
When simply flashed into the PIC, it's working perfectly :
the LED is blinking twice, and the accordingly the TSOP input (remote control receiver)
But when using the HID bootloader from Microchip modified for the 18F2550, I have some problems :
without the line
it's still working
but WITH that line, the PIC hangs (very fast LED blinking then nothing)
What kind of conflict could I have?
Thanks in advance for your reply
Philippe
PostPosted: Fri Nov 14, 2008 3:51 pm     Reply with quote
Obvious question is how the interrupt redirection is handled in the bootloader.
philippe320
PostPosted: Sun Nov 16, 2008 4:28 am     Reply with quote
YES ! Laughing
very very strange :
after many and many tests, I reinstalled CCS, and thus the USB files, recompiled everything and ...
IT'S WORKING !
(I probably modified something the the usb drivers files ...)
thank you Ttelmah for your reply
Philippe
