I need to use the output pin C1 -2 in PWM mode of the micro PIC16F877.
And, I use two switch control, by each switch need to ouput PWM 3 signal (or 3 duty cycle).
For the use control DC motor
Anyone can help me please ?
Thanks you very much.
Posted: Wed Nov 19, 2008 1:08 pm
I'm sorry to disturb
I want use to the source code concern the switch use control output PWM 3 value each one switch.
Because I write program don't working.
