Hagar
| Header Files |
Posted: Sat Nov 15, 2008 7:27 pm |
Hi all!
I'm trying to use CCS (version 3.249) to build some code for a PIC18F8680. I'd like to code
dividing the code in "modules", where each module would have a header file
(.h) and a source file (.c). I have always coded this way with 8051, MSP and
others devices, but I just can't figure out what I'm doing wrong with CCS.
Any idea? Thank you so much!
Below the code I'm using to test and the error message I'm getting.
File: main.c
#include <18F8680.h>
#include "SerialI2C.h"
//Microcontroller configuration bits
#fuses HS,NOOSCSEN,NOPROTECT,NOCPD,NOLVP,MCLR,PUT,BROWNOUT,BORV42,WDT,WDT256
void initPeripherals(void);
initPeripherals();
I2C_init();
delay_ms(50);
File SerialI2C.h:
#ifndef _SERIAL_I2C_
#define _SERIAL_I2C_
void I2C_init(void);
#endif //_SERIAL_I2C_
File SerialI2C.c:
void I2C_init(void)
Build message:
Executing: "C:\Arquivos de programas\PICC\Ccsc.exe" +FH "main.c" +EXPORT I+="C:\Dashboard\Dashboard_fw2" +DF +LN +T -A +M -Z +Y=0 +EA
>>> Warning 203 "C:\Dashboard\Dashboard_fw2\main.c" Line 27(1,1): Condition always TRUE
C:\Dashboard\Dashboard_fw2\main.o ===> 0 Errors, 1 Warnings.
Executing: "C:\Arquivos de programas\PICC\Ccsc.exe" +FH "SerialI2C.c" +EXPORT I+="C:\Dashboard\Dashboard_fw2" +DF +LN +T -A +M -Z +Y=0 +EA
*** Error 128 "C:\Dashboard\Dashboard_fw2\SerialI2C.h" Line 4(1,2): A #DEVICE required before this line
C:\Dashboard\Dashboard_fw2\SerialI2C.o ===> 1 Errors, 0 Warnings.
Skipping link step. Not all sources built successfully.
BUILD FAILED: Sat Nov 15 21:42:03 2008 |
Posted: Sun Nov 16, 2008 3:22 am |
Also, the obvious thing that the configuration stuff needs to be before your own includes. So the order must be:
//Select processor
//Configure processor
//Setup timings
//Now include your modules
There is a lot of 'basic' stuff in the CCS code, which _requires_ the configuration data to be present (almost everything!. - serial handling, timings, etc. etc.).
