An array of Strings
M0KHZ
An array of Strings
PostPosted: Wed Nov 12, 2008 11:41 am     Reply with quote
I've gone around in circles regarding this issue, and don't understand
why the code below doesn't compile.
compiler - Version 3.249
compiler error message:
Array of bits not permitted
Any ideas?
// Define string array 12 strings of length 20 characters
char band_text[12][20];
// Now we need to load the array with the text
strcpy(&band_text[0][0],"Band = 160 Meters   ");
strcpy(&band_text[1][0],"Band = 80 Meters    ");
strcpy(&band_text[2][0],"Band = 40 Meters    ");
strcpy(&band_text[3][0],"Band = 30 Meters    ");
strcpy(&band_text[4][0],"Band = 20 Meters    ");
strcpy(&band_text[5][0],"Band = 17 Meters    ");
strcpy(&band_text[6][0],"Band = 15 Meters    ");
strcpy(&band_text[7][0],"Band = 12 Meters    ");
strcpy(&band_text[8][0],"Band = 10 Meters    ");
strcpy(&band_text[9][0],"Band = 6 Meters     ");
strcpy(&band_text[10][0],"Band = Spare 1      ");
strcpy(&band_text[11][0],"Band = Spare 2      ");
I'm planning to use this array like this:
printf(LCD_PUTC,"%s",&band_text[band_pointer][0]);
Kevin - M0KHZ
treitmey
PostPosted: Wed Nov 12, 2008 12:05 pm     Reply with quote
Take out the & (address of) operator and the second [0] and you get a proper address.
  strcpy(band_text[0],"Band = 160 Meters  \0");
  strcpy(band_text[1],"Band = 80 Meters   \0");
  strcpy(band_text[2],"Band = 40 Meters   \0");
note: these are NOT strings, unless you didn't leave room for the \0 string terminator!
Wayne_
PostPosted: Thu Nov 13, 2008 3:08 am     Reply with quote
treitmey is basically correct but if you need strings of 20 char then create your array with string size of 21 to allow for the null terminating char.
char band_text[12][21];
strcpy(band_text[0],"Band = 160 Meters ");
&band_text[0][0] and band_text[0] do the same thing so you should be able to use eather method.
treitmey
PostPosted: Thu Nov 13, 2008 8:55 am     Reply with quote
Ahh, I see. From the manual
Copies a constant or RAM string to a RAM string. Strings are terminated with a 0.
looks like it will put in the \0 itself. Just need to have room.
M0KHZ
PostPosted: Fri Nov 14, 2008 2:07 pm     Reply with quote
Sorry for the delay in responding, but the day job has got in the way of fun!
Thanks for the answer guys. It's now working.
Kevin - M0KHZ
John P
PostPosted: Fri Nov 14, 2008 3:40 pm     Reply with quote
That was an incredibly misleading error message! Array of bits, indeed.
But you could save a lot of RAM space if you used shorter strings, and did the printing as:
printf(LCD_PUTC, "BAND = %s", band_text[0]);
where each string would be loaded like this:
strcpy(band_text[0], "160 Meters ");
and so forth.
PostPosted: Fri Nov 14, 2008 4:32 pm     Reply with quote
Thanks John, this method is a whole lot smarter Very Happy
Kevin - M0KHZ
