RS485 & STISR.C, SISR.C
Pontus
PostPosted: Thu Nov 13, 2008 2:34 pm     Reply with quote
Hi
I've found a very useful SISR.C and STISR.C (including bkbhit(),bgetc() functions etc...) as examples for sending and receiving buffers over UART in my compiler (4.057), and I've already used them to write a protocol for sending data (2 bytes ) between two PICs over RS232.
I'm looking for the same thing but with RS485. Is it possible to use those routines with just a little modification ?
thanks.
PostPosted: Fri Nov 14, 2008 3:23 am     Reply with quote
No modification at all....
The chip, does not develop either RS232, or RS485. It generates TTL async serial, which can be made into RS232, by adding a transceiver like the MAX232, or into RS485, by adding a MAX485. It is a 'pity', that CCS elected to call their routines and setup 'RS232'.
The code used is identical for RS232, or RS485, except for adding things like direction control to the RS485 transceiver, if operating in half-duplex mode if needed.
