pic24f problem??
tugrulex84
pic24f problem??
PostPosted: Thu Nov 13, 2008 7:57 am     Reply with quote
hi;
I wrote an easy program with my CCS C compiler to see pic24f but it doesn't work. When I try this kind of program for 16f it works but with pic 24F it doesn't work and gives 17 errors. I don't understand the problem. I need help. Thank you.
#include <24FJ64GA006.h>
#device adc=8
#FUSES XT                       //Crystal osc <= 4mhz
#FUSES PR                    #FUSES NOCKSFSM              #FUSES NODEBUG                  //No Debug mode for ICD
#FUSES NOSYNC                   //No sync between I/O and clock
#FUSES BORV47                #FUSES LPOL_HIGH                //Low-Side Transistors Polarity is Active-High (PWM 0,2,4 and 6)
#FUSES HPOL_HIGH                //High-Side Transistors Polarity is Active-High (PWM 1,3,5 and 7)
#FUSES NOPWMPIN                 //PWM outputs drive active state upon Reset
#FUSES MCLR                     //Master Clear pin enabled
#FUSES INT250KHZ                //Internal 250 khz Osc
#FUSES INT125KHZ                //Internal 125 khz Osc
#FUSES RESERVED                 //Used to set the reserved FUSE bits
   Reserved
#FUSES RC_IO                    //Resistor/Capacitor Osc
#use delay(clock=4000000,RESTART_WDT)
   setup_adc(ADC_OFF);
   setup_psp(PSP_DISABLED);
   setup_spi(FALSE);
   setup_timer_1(T1_DISABLED);
   setup_vref(FALSE);
   setup_low_volt_detect(FALSE);
   setup_oscillator(False);
   // TODO: USER CODE!!
output_high(pin_B0);
delay_ms(250);
output_low(pin_B0);
delay_ms(250);
PostPosted: Thu Nov 13, 2008 1:02 pm     Reply with quote
I see, that you are using a lot of fuses, that is unknown by PIC24F. There's an info page Valid Fuses in PCWHD, check it.
