PIC18F4685 - which CAN header?
matt1971
PostPosted: Sat Nov 08, 2008 2:55 pm     Reply with quote
Which is the best header file to use with a PIC18F4685 for CAN ? I'm using the ECAN module direct, so no use of any MCP* devices. Is the can-18xxx8.h compatible, or is 18F4580.h better ? Or do neither work !!
PostPosted: Sun Nov 09, 2008 1:52 pm     Reply with quote
You mean which CAN driver is best for the 18F4685. CCS has two
drivers. One is for the 18F458, and the other is for the 18F4580.
The 18F4580 and 18F4685 both have ECAN modules and are similar,
so the 18F4580.h driver would be the best choice.
