Rand() returns same values
Alvaro
PostPosted: Fri Nov 07, 2008 1:24 pm     Reply with quote
Hi, I do not have a good English, I occupy a translator.
I'm doing a game of dices, but the function Rand () always returns the same values, in C we can occupy srand (time ()) with time() but in PIC C is not the function time ().
I am using the PIC16F877A
In short I am doing this:
srand(7); //Should be srand(time());
randomNum= (rand()%6)+1; //range 1-6
randomNum2= (rand()%6)+1;
setDice(randomNum,1); //setDice function that I did
setDice(randomNum2,2);
I tried to do 1000 forms, but always returns the same order of values
Please help!!!
PostPosted: Fri Nov 07, 2008 1:49 pm     Reply with quote
srand(7);
It's not a random number generator. It's a pseudo random
number generator. The srand() function sets the initial state of the
generator. You are using the same seed (7) every time. So you
will get the same sequence every time. To change the sequence
you need to use a different seed.
These threads discuss the problem of how to generate the seed:
http://www.ccsinfo.com/forum/viewtopic.php?p=83928
http://www.ccsinfo.com/forum/viewtopic.php?t=27007
http://www.ccsinfo.com/forum/viewtopic.php?t=1313
Alvaro
THANKS
PostPosted: Fri Nov 07, 2008 2:00 pm     Reply with quote
Thank you very much,
I took the link: http://www.ccsinfo.com/forum/viewtopic.php?t=1313
Works!!!
