Using 18F4680 to create an FTP server
saddy
PostPosted: Fri Oct 31, 2008 9:38 am     Reply with quote
Hey guys,
How can a create an ftp server using 18f4680? Is there any sample code available which can be used to do this?
Rumple
FvM
PostPosted: Fri Oct 31, 2008 10:13 am     Reply with quote
There's a FTP server example in the TCP-IP PIC example sources, downloadable for licensed CCS C users.
saddy
PostPosted: Fri Oct 31, 2008 10:20 am     Reply with quote
What is the example number? I have the TCP/IP program list which I got when I bought the embedded internet kit.
FvM
PostPosted: Fri Oct 31, 2008 11:52 am     Reply with quote
It's an option in the stacktask(), used in the example ex_st_webserver2.c
saddy
PostPosted: Fri Oct 31, 2008 1:54 pm     Reply with quote
Well the TFTPServerAddr you are talking has not been used in any example, so as I said earlier, is there a working example I can use to refer for my project?
Saddy
PostPosted: Fri Oct 31, 2008 2:00 pm     Reply with quote
Run a text search program such as Examine32 on the CCS TCP-IP
examples directory. Search for: FTP Server
You will get these results:
c:\program files\picc\tcp-ip\pic examples source\ex_st_webserver2.c
////    Improvement to the TFTP server               ////
c:\program files\picc\tcp-ip\pic examples source\tcpip\ftp.c
SM_FTP           smFTP;          // ftp server FSM state
c:\program files\picc\tcp-ip\pic examples source\tcpip\tftp.c
/// TFTP_PORT - The TCP/IP port the TFTP server will listen to for TFTP
c:\program files\picc\tcp-ip\pic examples source\tcpip\ftp.h
 *              FTP Server Defs for Microchip TCP/IP Stack
saddy
PostPosted: Fri Oct 31, 2008 4:31 pm     Reply with quote
Thanks PCM,
But I could not find it my folder, is there anyway I can download it from CCS or something?
Saddy
PostPosted: Fri Oct 31, 2008 5:55 pm     Reply with quote
FvM said this:
The button for the TCP-IP package is in the bottom right corner of this page:
http://www.ccsinfo.com/compilerupdates.php
You need to have current "maintenance" in effect, to be allowed to
download the files.
saddy
PostPosted: Mon Nov 03, 2008 11:16 am     Reply with quote
I downloaded the example files, but I am still unable to use this, is there a simple example which uses the ftp.c and ftp.h ?
Guest_101
PostPosted: Tue Nov 04, 2008 2:34 pm     Reply with quote
I dont think there is even a documentation on ftp.c and ftp.h . So i think you are on your own.
meereck
PostPosted: Tue Nov 04, 2008 5:40 pm     Reply with quote
has anyone written a FTP Client for CCS?
I have a GPRS modem with a TCP/IP stack built, and I am looking for a FTP client library.
cheers
PostPosted: Tue Nov 04, 2008 5:42 pm     Reply with quote
I don't think there is even a documentation on "ftp.c" and "ftp.h".
The CCS driver is based on the Microchip stack. The Microchip appnote
AN833 talks about the "FTP.c" file on page 85. Here's the link:
http://ww1.microchip.com/downloads/en/AppNotes/00833c.pdf
