Setting known state in an 8-bit register.
stevekos
PostPosted: Sat Apr 24, 2010 9:35 am     Reply with quote
Good afternoon.
This is a silly question, but I can't seem to figure out how to
set a bit in a register LOW in C. I know how to do it in assembly,
but for some reason I can't do it in C.
Let me give you an example:
I have a 8 position DIP switch on PORTB. I want to ignore RB6 and RB7
but get the values of the other 6 positions. So I am reading in portb into
a shadow register and I want to set RB6 and RB7 LOW.
I am drawing a blank, and I searched for this but something tells me it is
so simple that I am the only person "that doesn't get it" ... Smile
Thanks in advance.
Steve
Humberto
PostPosted: Sat Apr 24, 2010 10:45 am     Reply with quote
#define MASK 0x3F       // =0b00111111 Pre-processor directive
unsigned int DIP_Sw;    // Variable to store the the DIP switch value
main()
    DIP_Sw = PORTB & MASK;  // Read the whole PORTB, then AND with MASK and place the result in the variable DIP_Sw
Humberto
