Reading I/O port problem
PROYEX
PostPosted: Sat Nov 01, 2008 1:04 pm     Reply with quote
Reading the compiler manual I can't find any instruction for reading the
entire port (for example reading the 8 bits of portb from b0 to b7)) at
same time. In PicBasic I made that with peek command to read the
entire bit, but in C I only find input pin command. So if want to read 8
bits I must repeat 8 times this command, any suggestion? Thanks
n-squared
PostPosted: Sat Nov 01, 2008 1:52 pm     Reply with quote
look for input_a(), input_b() etc.
Best regards
Every solution has a problem.
