Character array to long?
davidbue
PostPosted: Mon Oct 27, 2008 5:08 pm     Reply with quote
Hi everybody.
I've got a little problem. Through hyperterminal the user must be able to type in a number which then is used as setpoint for a PID algorithm.
The number can be anything between 1-1000
My code right now looks like this:
char string[10];
long frequency;
... lots of irrelevant code ...
gets(string);
Now! Let's assume the user typed 978. How do I convert the character array to a long? Should I maybe use an all different approach?
Thank you for your help!
PostPosted: Mon Oct 27, 2008 5:35 pm     Reply with quote
Consider that for common problems like this, the C language will
already have a solution -- it's the series of functions known as
"atoi" (ASCII to Integer). In this case, you want a 16-bit result,
so use the version of it called "atol" (ASCII to long). It's in the
CCS manual.
davidbue
PostPosted: Tue Oct 28, 2008 1:09 am     Reply with quote
Hi PCM programmer!
I'm so sorry. I forgot to say... I'd like to not use the atoil() as the stdlib.h eats up waaay to much memory when included. :-D
I'm looking for an alternative way to capture the number.
Sorry for the missing information, and thank you so much for your answer.
Best regards
David
PostPosted: Tue Oct 28, 2008 1:16 am     Reply with quote
You can use a truncated version of it. See the adtol (ASCII Decimal
to Long) function in this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=17563&highlight=adtol
