eng/ IBRAHIM
DIMMER |
Posted: Sat Oct 25, 2008 6:24 am |
hi
pls
i want to mak a lamp dimmer by use 12c508 .i find this code in microchip site but it not written by CCS how can convert to CCS compiler
#pragma option v;
#include <12C508.h>
/* DIMMER.C
/* Lamp dimmer for the 12C508.
/* This program uses the internal 4MHz oscillator
/* To drive TRIAC, the output is taken high
/* or put in high-impeadance(open drain) to release it
/* NOTE: This program is designed to work with a 60Hz
/* line frequency, it must be modified if used
/* on a 50Hz AC line.
/* GPIO<0> = Dim button
/* GPIO<1> = No Connect
/* GPIO<2> = Output to TRIAC
/* GPIO<3> = Bright Button
/* GPIO<4> = Zero Crossing sense input
/* GPIO<5> = No Connect
#defineBrtbut GPIO.0 //Brighten button
#define Output GPIO.2 //Output to TRIAC
#define Dimbut GPIO.3 //Dim button
#define LineInput GPIO.4 //AC line zero crossing sense
void Buttoncheck(void); //Button check routine
unsigned int PercentOn, Maxdim; //Global variables
unsigned int TestCheck, Outcount, TestCount;
unsigned int DelayCnt;
unsigned int LastBoth, FirstPass;
unsigned int Count;
const Maxbrt = 0xFD, NotInTest = 3;
PercentOn = 0xD0; //On Period
Maxdim = 0x70; //Value of Maximum dimming
TestCheck = 0; //Test mode check counter
Outcount = 0; //Counter for test mode exit
TestCount = 0; //Test mode counter
DelayCnt = NotInTest; //Delay count
LastBoth = 0; //Both buttons pressed last time flag
FirstPass = 1; //Indicate power-up
Count = 0; //General counter
for(Count = 0; Count < 60; Count++) //Allow power supply to stabilize
while(LineInput == 1);
while(LineInput == 0);
CLRWDT;
WREG = 0x85;
#asm ( OPTION); //1:64 tmr0 prescaler, pullups enabled
WREG = 0x1D;
#asm ( TRIS GPIO); //Set up I/O
GPIO = 0x04; //Set TRIAC output latch high
while(LineInput == 1) //Synch to line phase
CLRWDT;
TMR0 = PercentOn; //Get Delay time
while(TMR0 >= 3 && LineInput == 0) //Delay to enter main at proper point
CLRWDT;
while(1) //Stay in this loop
Count = 0;
while (Count++ < DelayCnt) //Check for button press every
DelayCnt zero crossings
if(LineInput == 1) //Check for AC line already high
Maxdim += 5; //If so, increment Maxdim
while(LineInput == 1); // and re-sync with line
CLRWDT;
while(LineInput == 0) //Wait for zero crossing
CLRWDT;
Maxdim = PercentOn - TMR0 + 2; //Compensate full dim value for line
// frequency vs osc. speed
if(FirstPass == 1) //If first pass, go to full dim
FirstPass = 0;
PercentOn = Maxdim;
if(PercentOn < Maxdim) //If maxdim moved, fix brightness
PercentOn = Maxdim;
TMR0 = PercentOn; //Get delay time
while(TMR0 >= 3 && LineInput == 1) //Delay TRIAC turn on (wait for Counter rollover)
CLRWDT;
WREG = 0x19;
#asm ( TRIS GPIO); //Fire TRIAC
NOP; //Delay for TRIAC fire pulse
NOP;
NOP;
NOP;
NOP;
NOP;
NOP;
WREG = 0x1D;
#asm ( TRIS GPIO); //Release TRIAC fire Signal
CLRWDT;
if(LineInput == 0) //Check for AC line already low
while(LineInput == 0); // and re-sync with line
CLRWDT;
while(LineInput==1) //Wait for zero crossing
CLRWDT;
PercentOn = Maxdim;
while(TMR0 >= 3 && LineInput == 0) //Delay TRIAC turn on
CLRWDT;
WREG = 0x19;
NOP;
NOP;
NOP;
NOP;
NOP;
NOP;
WREG = 0x1D;
#asm ( TRIS GPIO); //Release TRIAC fire signal
CLRWDT;
Buttoncheck(); //Check for button press
/* ButtonCheck */
/* This subroutine checks for presses on the BRT and DIM */
/* buttons and increments or decrements PercentOn. */
/* If both buttons are pressed and the lamp */
/* is not off, it is turned off, if off, it is set to */
/* to max bright. */
/* In addition, a test function is built in. If both */
/* buttons are pressed, the dim let go and then pressed */
/* again, test mode is entered. If dim is pressed */
/* (alone), the program goes to normal operation at max */
/* dim. The test mode brightens to full bright, dims to */
/* full dim, flashes full bright twice, and repeats. */
void Buttoncheck()
NOP; //Bugfix for MPLABC V1.10
if(TestCheck == 3) //Check test mode flag
DelayCnt = 2; //Reset the delay count
if(Brtbut && !Dimbut) //If Dimbutton pressed, exit test mode
TestCheck = 0; //Clear Test mode flag
DelayCnt = 5;
return;
if(TestCount == 0) //Ramp up to full dim
if(++PercentOn > Maxbrt) //Check for full bright
PercentOn = Maxbrt;
++TestCount;
return;
return;
if(TestCount == 1) //Ramp down to full dim
if(--PercentOn <= Maxdim) //Check for full dim
PercentOn = Maxbrt;
++TestCount;
return;
return;
while(TestCount++ < 5) //Delay
return;
while(TestCount++ < 10) //Turn off for a short period
PercentOn = Maxdim;
return;
while(TestCount++ < 15) //Turn On for a short period
PercentOn = Maxbrt;
return;
while(TestCount++ < 20) //Turn off for a short period
PercentOn = Maxdim;
return;
while(TestCount++ < 25) //Turn on for a short period
PercentOn = Maxbrt;
return;
while(TestCount++ < 30) //Turn off for a short period
PercentOn = Maxdim;
return;
PercentOn = Maxdim;
TestCount = 0; //Reset to beggining of test sequence
if(++Outcount == 255) //Run 255 cycles of test mode
Outcount = 0;
return;
if(TestCheck) //If Test mode not entered quickly,
if(++Outcount == 0x60) // quit checking
Outcount = 0;
TestCheck = 0;
if(!TestCheck && !Brtbut && !Dimbut) //Check bright & dim at same time
TestCheck = 1; //If both pressed, set to look for next combo
if(TestCheck == 1 && !Brtbut && Dimbut) //Check for only bright button pressed
TestCheck = 2; //If pressed, set to look for next combo
if(TestCheck == 2 && !Brtbut && !Dimbut) //Check for both pressed again
TestCheck = 3; //Enable test mode
TestCount = 0;
PercentOn = Maxdim;
Outcount = 0;
if(!Dimbut && !Brtbut) //If both pressed
if(LastBoth == 0) //Don't flash if held
LastBoth = 1;
if(PercentOn == Maxdim) //If full off...
PercentOn = Maxbrt; // turn full on...
PercentOn = Maxdim; // otherwise turn off
LastBoth = 0;
if(!Brtbut && Dimbut) //Check for brighten cmd
PercentOn ++;
if(Brtbut && !Dimbut) //Check for dim cmd
PercentOn --;
if(PercentOn > Maxbrt) //If greater than full bright
PercentOn = Maxbrt;
if(PercentOn < Maxdim) //If less than full dim
PercentOn = Maxdim;
RLScott
Re: DIMMER |
Posted: Sat Oct 25, 2008 6:31 am |
eng/ IBRAHIM wrote: | hi
pls
By understanding all the features of this code that are unique to that other compiler and then finding the corresponding functions in the CCS compiler. If you are too lazy to at least give it a try, then why should anyone else bother? _________________ Robert Scott
Real-Time Specialties
Embedded Systems Consulting |
dyeatman
Posted: Sat Oct 25, 2008 7:57 am |
This is proprietary Microchip code from an application note and they may not be happy with it being copied and reproduced here. |
eng/ IBRAHIM
Posted: Sat Oct 25, 2008 8:06 am |
Hi
Thanks RLScott
I'm not lazy but I try to make dimmer by PIC to control in AC motor since long time.
I try you said and I change a lot of function but i not understand more functions because i using CCS compiler only. After change function the compiler gives error and so on. And the code including assembly function. |
Posted: Sat Oct 25, 2008 8:36 am |
This is pretty simple code, only a few pages long. Reverse engineer it - that is make a flow chart of how the code works. Then code your flow chart in CCS C.
This is called: "Reverse Engineering" and it is done all the time by all of us when we are trying to understand nearly everything.
By spending your time learning how to do this you will be a better engineer. But it takes effort and time on your part. The time you spend learning this now will pay off for your entire life. So it is an investment in YOUR future.
HTH - Steve H. |
