Accessing hi byte of int16 in assembly
embedded_tom
PostPosted: Mon Oct 20, 2008 8:36 am     Reply with quote
I read through the forum and found a way to do this by using the '&' prefix: http://www.ccsinfo.com/forum/viewtopic.php?t=7220
   bcf     TMR1ON
   movf    Next_Time, W
   addwf   TMR1, F
   btfsc   C
   incf    TMR1H, F
   movf    &Next_Time+1, W
Next_Time is located at 0x28 according to the .lst file:
Next_Time                         00000028
But it doesn't access 0x29 in the second movf!?!
                00484 ....................    bcf     TMR1ON
0015 1010       00485 BCF    10.0
                00486 ....................    movf    Next_Time, W
0016 0828       00487 MOVF   28,W
                00488 ....................    addwf   TMR1, F
0017 078E       00489 ADDWF  0E,F
                00490 ....................    btfsc   C
0018 1803       00491 BTFSC  03.0
                00492 ....................    incf    TMR1H, F
0019 0A8F       00493 INCF   0F,F
                00494 ....................    movf    &Next_Time+1, W
001A 082A       00495 MOVF   2A,W
Adding parenthesis or dropping the "+1" doesn't work. Next_Time is declared as an int16.
My compiler is Ver 4.080. uP is rfPIC12F675 (12F675 w/RF transmitter).
Ideas?
Thanks.
Tom
RLScott
Re: Accessing hi byte of int16 in assembly
PostPosted: Mon Oct 20, 2008 8:59 am     Reply with quote
Try this:
#byte Next_Time_H=Next_Time+1
   movf  Next_Time_H,W
This has the advantage of also working outside of the assembly language block as in:
   int  k;
  k = Next_Time_H;
Robert Scott
Real-Time Specialties
Embedded Systems Consulting
embedded_tom
PostPosted: Tue Oct 21, 2008 7:26 am     Reply with quote
Thanks, but got this error for the #byte statement: Error 43 Expecting a declaration.
tom
RLScott
PostPosted: Tue Oct 21, 2008 7:30 am     Reply with quote
tom
Please post the code showing how you used the #byte directive. It is a valid CCS directive. Look it up in the CCS help file.
Robert Scott
embedded_tom
PostPosted: Tue Oct 21, 2008 7:34 am     Reply with quote
I did review #byte in the CCS manual. Here's what I used:
#byte Next_TimeH = Next_Time + 1;
Is #byte similar to "assign" in other compilers?
I just tried this & it worked:
   movf    make8(Next_Time,1), W
Thanks for the push in the right direction!
tom
RLScott
PostPosted: Tue Oct 21, 2008 9:20 am     Reply with quote
The problem is the ';' at the end. Take it off and it should work.
Robert Scott
embedded_tom
PostPosted: Tue Oct 21, 2008 2:30 pm     Reply with quote
Yep, that did it.
Thanks.
tom
