Changing CCP1 pin on the 16F88
localboy
PostPosted: Tue Oct 28, 2008 10:30 am     Reply with quote
The CCP1 module can change pins between RB0 and RB3 on the 16F88, RB0 is the default. How do I set it up for pin RB3 in the code?
PostPosted: Tue Oct 28, 2008 10:46 am     Reply with quote
Look at the list of fuse settings at the top of the 16F88.h file.
You will find what you need there.
