I2C routine speed
IT
I2C routine speed
PostPosted: Mon Apr 07, 2003 5:05 pm     Reply with quote
Used CCS routines for I2C comunications with a 20 Mhz clock, how much time spend each byte in the bus?
I have an application with an EEPROM memory 24C515 and the time is critical. If the speed of the bus I2C is too low, is there any other component EEPROM or Flash more quick than 24Cxx EEPROM family?
A lot of thanks,
___________________________
Original Post ID: 13472
Re: I2C routine speed
PostPosted: Mon Apr 07, 2003 5:24 pm     Reply with quote
:=Hello,
:=Used CCS routines for I2C comunications with a 20 Mhz clock, how much time spend each byte in the bus?
:=I have an application with an EEPROM memory 24C515 and the time is critical. If the speed of the bus I2C is too low, is there any other component EEPROM or Flash more quick than 24Cxx EEPROM family?
I think you really mean 24LC515, not 24C515.
Ramtron has EEPROM with a fast write time, and a fast interface.
This chart shows the bus speed of the various chips:
<a href="http://www.ramtron.com/products/datasheets.htm" TARGET="_blank">http://www.ramtron.com/products/datasheets.htm</a>
This appnote compares the time required to access a Ramtron
eeprom, vs. a normal eeprom.
<a href="http://www.ramtron.com/products/appnotes/24C16adv.pdf" TARGET="_blank">http://www.ramtron.com/products/appnotes/24C16adv.pdf</a>
You can use Hardware i2c, and program the SSPADD register for
a higher baud rate, to use with these high-speed eeproms.
Or, you could use SPI.
Original Post ID: 13473
