PIC16F877
Jan
PIC16F877
PostPosted: Mon Apr 07, 2003 8:58 pm     Reply with quote
I use PIC16F877 microcontroller and have problem with full dublex RS232 connection. When sending data to hyperterminal,I can only send but not recive data, using getc().
___________________________
Original Post ID: 13477
Pete Smith
Re: PIC16F877
PostPosted: Tue Apr 08, 2003 1:20 am     Reply with quote
:=I use PIC16F877 microcontroller and have problem with full dublex RS232 connection. When sending data to hyperterminal,I can only send but not recive data, using getc().
I've had problems similar to this in the past. When I'm sending data constantly, and not receiving it using an interrupt driven recieve routine, I'd always miss data going both ways.
The reason was that while the PIC was sending, it wasn't receiving, and vice versa.
To get round this you should use 3 things...
1) Get rid of Hyperterm, and use Teraterm instead. I don't know the URL, but do a search on this board, and you'll get a result.
2) Use an interrupt driven serial port receive routine (it's been discussed here plenty of times).
3) Use an interrupt driven serial port transmit routine - again it's been discussed here before.
HTH
Pete.
Original Post ID: 13482
