mah115 Guest
| Timer5 Period Match with PICC |
Posted: Thu Oct 30, 2008 10:05 am |
I'm trying to use PIC C with the PIC18F4431, and I'm trying to make the PIC generate an interrupt on a TIMER5 period match. However, the setup_timer_5(MODE,PERIOD) function won't work, only the setup_timer_5(MODE) works. This means I can't set the period match register, when I should be able to.
I also tried writing directly to the memory location of PR5, but that doesn't work either. Anyone know how to set the period match register?
int* PR5L;
int* PR5H;
PR5L = 0x70;
PR5H = 0x71;
*PR5H = 100/256;
*PR5L = 100%256;
RLScott
| Re: Timer5 Period Match with PICC |
Posted: Thu Oct 30, 2008 10:23 am |
#byte PR5L=0x70
#byte PR5H=0x71
PR5H = 100/256;
PR5L = 100%256;
_________________ Robert Scott
Real-Time Specialties
Embedded Systems Consulting |
Posted: Thu Oct 30, 2008 10:36 am |
However, read the data sheet.
The timer5 registers are at 0xF87, and 0xF88, not 70 and 71.
Posted: Thu Oct 30, 2008 11:36 am |
| Ttelmah wrote: | However, read the data sheet.
Ah, good catch. PR5 is actually 0x90 and 0x91; I was reading the wrong column. |
