atomy_kwang
| Help me about sensor and GSM module |
Posted: Fri Oct 10, 2008 6:41 am |
#include <16F877.h>
#fuses HS,NOLVP,NOWDT,NOPROTECT
#use delay(clock = 20000000)
#use rs232(baud=9600,xmit=pin_c6,rcv=pin_c7)
#byte port_b=6
char phone_num[13]="+xxxxxxxxxxx" ;
char ctrl_z=0x1A ;
char CR = 0x0d ;
char LF = 0x0a ;
void send_sms(void)
if(!input(PIN_B4))
printf("at+cmgs=\"%s\"\n\r",phone_num);
printf("%c\n\r",CR);
printf("%c\n\r",LF);
printf("Products were sold out in Chatuchak area\n\r");
printf("%c\n\r",ctrl_z);
port_b=0x00;
void blink_led()
output_toggle(PIN_B7);
set_tris_b(0xF0);
blink_led();
while(true)
send_sms();
i would like to send sms if my sensor can detect a light from led
but i have a problem. When sensor detect the sms were sent all time
but i would like to send it enought 1 time
Please help me
thank you |
Posted: Fri Oct 10, 2008 9:18 am |
When you run the program, does the LED stay on, or does it flash once and stay off? I would try using output_toggle, output_high and output_low. You don't have to use set_trisb() then.
If you only want to send one message per light reception, you'd probably be better off connecting the sensor to an external interrupt. In the interrupt service routine, set a flag. in the while(true) loop in main(), poll that flag. If the flag is set, clear it, and send your SMS. Also, you don't need to use the set_trisb() if you use output_toggle and output_low.
#include <16F877.h>
#byte port_b=6
char ctrl_z=0x1A ;
char CR = 0x0d ;
char LF = 0x0a ;
int1 sensor_flag=0;
#int_ext0
void ext0_isr()
sensor_flag=1;
void send_sms(void)
if(!input(PIN_B4))
output_low(PIN_B7);
void blink_led()
enable_interrupts(INT_GLOBAL);
enable_interrupts(INT_EXT0);
set_tris_b(0xF0);
blink_led();
while(true)
if(sensor_flag==1)
sensor_flag=0;
send_sms();
Just out of curiousity, what kind of hardware is sending the SMS? |
crystal_lattice
Posted: Fri Oct 10, 2008 11:22 am |
Just as a side note, your CR and LF after the printf containing the message is probably redundant as the \n\r does that for you...
printf("%c\n\r",CR); << dont't think this is needed
printf("%c\n\r",LF); << dont't think this is needed
