12F508/509 TRIS configuration
dan_bas
PostPosted: Thu Oct 09, 2008 6:35 am     Reply with quote
Reading the Microchip documentation this device does not provide an address for the TRISGPIO. In assembly you load your I/O config in x and execute a tris command.
Looking through the Forum at some of the examples it appears that I should be using:
set_tris_b(0x??);
to configure the I/O. Is this correct?
PostPosted: Thu Oct 09, 2008 1:07 pm     Reply with quote
That will work. You need to tell the compiler that you want to set TRIS
for Port B, by using the #use fast_io directive. See the manual.
But you can also just let the compiler set the TRIS. Don't use Fast i/o
mode, and don't write directly to Port B. Instead, use the CCS pin and
port i/o functions, such as output_low(), output_high, output_b(), etc.
These are in the manual. The compiler will "know" the proper TRIS
settings for the function that you use, and set the TRIS for you.
It's much easier to write programs this way. It's one of the good things
about the CCS compiler (which is not even advertised as an important
feature).
