printf(""); problem
louishuynh
printf(""); problem
PostPosted: Thu Oct 02, 2008 11:32 am     Reply with quote
I have a problem with sending a msg through the RS-232. Here is the detail of my program:
1-When the PIC16F916 is powered on: the 2 LED (Passed and Failed) will flash 1 time
2-If the Switch is pressed and released: The 2 LEDs will flash 3 times, after that the msg "Hello!" will be displayed on the screen - And then the 2 LEDs will flash 2 other times and it will turn OFF
Problem:
After the 2 LEDs have flashed 3 times, then the line of code: "printf("Hello!");" should be executed but somehow this line of code is not executed, nothing is displayed and the program is stuck there.
I did put “#use delay(clock=4000000) and #use rs232(baud=9600, parity=N, xmit=PIN_C6, rcv=PIN_C7, bits=8)" at the beginning of the program.
Any help will be appreciated, thanks
Here is my program:
#include <16F916.h>
#FUSES NOWDT
#FUSES INTRC_IO
#FUSES PUT
#FUSES NOPROTECT
#FUSES NOMCLR
#FUSES NOCPD
#FUSES BROWNOUT
#FUSES IESO
#FUSES FCMEN
#FUSES NODEBUG
#define SetPortA 0x2F
#define SetPortB 0x82
#define poLED_Failed PIN_B5
#define poLED_Passed PIN_B6
#define piSwitch_In PIN_B7
#define SetPortC 0x98
#define poTx PIN_C6
#define piRx PIN_C7
#define SetPortE 0x08
#use fast_io(a)
#use fast_io(b)
#use fast_io(c)
#byte PORTA =0x05
#byte PORTB =0x06
#byte PORTC =0x07
#byte PORTE =0X09
#byte STATUS =0x03
#byte INTCON =0x0B
#byte ANSEL =0x91
#byte ADRESH =0x1E
#byte ADCON0 =0x1F
#byte ADRESL =0x9E
#byte ADCON1 =0x9F
#byte OPTION =0x81
#byte WPU =0x95
#byte TXSTA =0x98
#byte RCSTA =0x18
#byte SPBRG =0x99
#byte TRISE =0x89
#byte OSCCON =0x8F
#byte OSCTUNE =0x90
int i;
SETUP_TIMER_0(RTCC_INTERNAL|RTCC_DIV_1);
SETUP_TIMER_1(T1_DISABLED);
SETUP_TIMER_2(T2_DISABLED,0,1);
SETUP_COMPARATOR(NC_NC_NC_NC);
SETUP_VREF(FALSE);
SETUP_SPI(FALSE);
SETUP_LCD(LCD_DISABLED);
SET_TRIS_A(SetPortA);
SET_TRIS_B(SetPortB);
SET_TRIS_C(SetPortC);
TRISE = SetPortE;
RCSTA = 0x00;
//Clear PortA, PortB, PortC and PortE
PORTA = 0;
PORTB = 0;
PORTC = 0;
PORTE = 0;
     for(;;)
      output_High(poLED_Failed);
      output_High(poLED_Passed);
_Wait:
          while (input(piSwitch_In)); //---------If the Switch is not pressed, keep waiting
          if (input(piSwitch_In))
               goto _Wait;
_Test0:
          while (!input(piSwitch_In)); //---------If the Switch is pressed but not released, keep waiting
          if (input(piSwitch_In)) //---------If the Switch is released, start the test
                 goto _Test1;
          goto _Test0;
_Test1:
          for(i=0; i<5;i++)
             output_Low(poLED_Passed);
             output_Low(poLED_Failed);
             if(i==2)
               printf("Hello!");
PostPosted: Thu Oct 02, 2008 9:26 pm     Reply with quote
You need to fix your code so it doesn't use "goto" statements. Most
people do not want to look at code that has goto statements. That's
probably why you have not received any replies so far.
Also, remove all unnecessary lines of code from your test program.
We don't want to look at all the #byte statements that are not used by
the program.
