#pin_select C1RX=PIN_B2
khtang
PostPosted: Fri Oct 03, 2008 3:49 am     Reply with quote
I am trying to remap the CAN TX and RX pins on PIC24HJ64GP502, but as per the PCD Reference manual June 2008 page 124 C1RX and C1TX. Can anybody verify this?
khtang
What am I doing..
PostPosted: Fri Oct 03, 2008 3:53 am     Reply with quote
I am trying to remap the CAN TX and RX pins on PIC24HJ64GP502, but as per the PCD Reference manual June 2008 page 124, C1RX and C1TX are not listed as supported pins. Can anybody verify this?
PostPosted: Fri Oct 03, 2008 4:23 am     Reply with quote
There are many device features not yet supported by PCD built-in functions respectively other dedicated elements as #PIN_SELECT. You can always set in- and output pin mapping in RPINRx and RPORx registers directly.
At present, it's a faster way to define all I/O mappings on your own rather than verifying the correct coding of the different #PIN_SELECT statements.
