How can I configure CAN bus to work at 250kbps
Pedr0
PostPosted: Fri Oct 03, 2008 8:51 am     Reply with quote
I know tbit=8xtq and brp 11.
The problem is where I edit this values ?
I'm using #import can-18xxx8.h
ty
FvM
PostPosted: Fri Oct 03, 2008 9:22 am     Reply with quote
You can redefine the CAN_BRG_xxx constants in your code prior to including can-18xxx8.h. The new values then take precendence over the default values. But please don't ask me about the appropriate values, cause I'm not familiar to CAN. I guess you find them in the device user manuals.
PostPosted: Fri Oct 03, 2008 2:28 pm     Reply with quote
See the large post in this thread which gives detailed instructions on how
to setup the bit timing parameters for the CAN bus:
http://www.ccsinfo.com/forum/viewtopic.php?t=22138
