PCD coding errors
PCD coding errors
PostPosted: Mon Sep 29, 2008 11:54 am     Reply with quote
I ported ex_modbus_slave.c to PIC24F and experienced a coding error, that causes failure of the respective operation (resulting in all zero output data in Coil and Input read). The erroneous behaviour can be easily seen in PCD assembly listing:
data = data & (0xFF>>(8-modbus_rx.data[3]));  //0 out values after quantity
02422:  MOV     #8,W4
02424:  MOV     8E8,W3  ; data
02426:  LSR     W3,#8,W3
02428:  SUB.B   W4L,W3L,W0L ; substract result to W0L
; here's the bug
0242A:  MOV     #FF,W0      ; mask also loaded to R0
0242C:  CLR.B   1
0242E:  LSR     W0,W0,W0
02430:  AND.B   950
Most likely, the error can be removed by rearranging the code. But iit's a serious problem, when any line of code must be suspected to be coded incorrect.
I experienced a similar problem one day before when porting some Microchip code (AN1095, Emulation of Data EEPROM in code memory). In this case, a wrong WREG address has been used at addr 018DA.
742:                   if(latch != (data & 0xFF))
 018D2  804800     mov.w 0x0900,0x0000  ; int16 data
 018D4  B20FF0     and.w #0xff,0x0000
 018D6  804864     mov.w 0x090c,0x0008  ; int8 latch
 018D8  EF6009     clr.b 0x0009
 018DA  E30004     cp.w 0x0004          ; must be cp.w 0x0008 !!
 018DC  320006     bra z, 0x0018ea
Both cases are related to int8 variables. The compiler version is V4.079.
Best regards,
Frank
