Clock/Temp code for 16F628 output_high/low problem
Aurbo
PostPosted: Mon Sep 29, 2008 10:24 am     Reply with quote
Greetings again.
I cannot get the led's attached to Pin_B4 to function. I've tried changing the high/low states several times but the led's remain on.
Any clues?
// DIGITAL thermometer project
// Compiler : CCS V 3.222
#include <16F628.h>
#fuses NOWDT,XT, NOPUT, PROTECT,NOLVP,NOMCLR,NOLVP  // for 628
//#fuses NOWDT,XT, NOPUT, PROTECT    // for 84a
#include <ds1820.c>
#define DS1307_SDA  PIN_A2
#define DS1307_SCL  PIN_A3
#use i2c(master, sda=DS1307_SDA, scl=DS1307_SCL)
byte CONST MAP1[10]={0xFA,0x30,0xD9,0x79,0X33,0x6B,0xEB,0x38,0xFB,0x7B};
byte CONST MAP2[10]={0xDE,0x18,0xCD,0x5D,0X1B,0x57,0xD7,0x1c,0xDF,0x5F};
byte sec,min,hour;
byte fs_flag;
#define EXP_OUT_LATCH   PIN_B7
#define EXP_OUT_CLOCK   PIN_B3
#define EXP_OUT_DO      PIN_B5
#define EXP_OUT_CLEAR   PIN_B6
#define colon           PIN_B4
#define DEC             PIN_B1
#define INC             PIN_B2
   BYTE buff[9], sensor, n,temp,temp_dec,RES;
   BYTE D_SHIFT;
// initial DS1307
void init_DS1307()
   output_float(DS1307_SCL);
   output_float(DS1307_SDA);
// write data one byte to
// DS1307
void write_DS1307(byte address, BYTE data)
   short int status;
   i2c_start();
   i2c_write(0xd0);
   i2c_write(address);
   i2c_write(data);
   i2c_stop();
   i2c_start();
   status=i2c_write(0xd0);
   while(status==1)
      i2c_start();
// read data one byte from DS1307
BYTE read_DS1307(byte address)
   BYTE data;
   i2c_start();
   i2c_write(0xd0);
   i2c_write(address);
   i2c_start();
   i2c_write(0xd1);
   data=i2c_read(0);
   i2c_stop();
   return(data);
// WRITE DATA TO 6B595
void write_expanded_outputs(BYTE *D)
  BYTE i;
  for(i=1;i<=8;++i)
  {  // Clock out bits from the eo array
    if ((D & 0x80)==0)
      output_low(EXP_OUT_DO);
      output_high(EXP_OUT_DO);
   D=D<<1;
   output_high(EXP_OUT_CLOCK);
   output_low(EXP_OUT_CLOCK);
// show temperature
void show_temp()
   int8 count;
    output_high(colon);
    for (count=0;count<8;count++)  // blink temperature 8 times
      output_low(EXP_OUT_LATCH);
      sensor=0;   // DS1820 CONNECT TO PIN A0
      init_ds1820(sensor);
      write_ds1820_one_byte(0xcc, sensor);  // skip ROM
      write_ds1820_one_byte(0x44, sensor);  // perform temperature conversion
      while (read_ds1820_one_byte(sensor)==0xff); // wait for conversion complete
      write_ds1820_one_byte(0xbe, sensor);  // read the result
      for (n=0; n<9; n++)     // read 9 bytes but, use only one byte
         buff[n]=read_ds1820_one_byte(sensor);  // read DS1820
      temp=buff[0]>>1;
      if ((buff[0] & 0x1)==1)
         temp_dec=5;
         temp_dec=0;
      D_SHIFT=0x00;
      write_expanded_outputs(D_SHIFT);
      D_SHIFT=0xE1;  // show 'C
      RES=TEMP%10;
      D_SHIFT=MAP1[RES];
      RES=TEMP/10;
      if (RES==0)
        D_SHIFT=0x00;
        D_SHIFT=MAP1[RES];
      output_high(EXP_OUT_LATCH);
      for (n=1;n<=4;n++)
         D_SHIFT=0x00;
// show time 1
void show_time1()
   byte m;
         output_low(colon);
         min=read_ds1307(1);
         hour=read_ds1307(2);
         m=min & 0x0F;
         D_SHIFT=MAP2[m];
         swap(min);
         m=min & 0x07;
         D_SHIFT=MAP2[m];
         m=hour & 0x0F;
         D_SHIFT=MAP1[m];
         swap(hour);
         m=hour & 0x03;
         D_SHIFT=MAP1[m];
         swap(min);
         swap(hour);
// check switch
void check_sw()
byte j;
   if (fs_flag!=0)
      if (!input(INC))
         if (fs_flag==1)
            min=read_ds1307(1);
            min++;
            j=min & 0x0F;
            if (j>=0x0A) min=min+0x06;
            if (min>=0x60) min=0;
            write_ds1307(1,min);
            hour++;
            j=hour & 0x0F;
            if (j>=0x0A) hour=hour+0x06;
            if (hour>=0x24) hour=0;
            write_ds1307(2,hour);
       show_time1();
      if (!input(DEC))
         if (fs_flag==1)
            min=read_ds1307(1);
            if (min!=0)
               min--;
               j=min & 0x0F;
               if (j>=0x0A) min=min-0x06;
            else min=0x59;
            if (hour!=0)
               hour--;
               j=hour & 0x0F;
               if (j>=0x0A) hour=hour-0x06;
            else hour=0x23;
       show_time1();
// show time
void show_time(byte fs)
   byte m;
         output_low(colon);
         min=read_ds1307(1);
         m=min & 0x0F;
         D_SHIFT=MAP2[m];
         swap(min);
         m=min & 0x07;
         D_SHIFT=MAP2[m];
         m=hour & 0x0F;
         D_SHIFT=MAP1[m];
         swap(hour);
         m=hour & 0x03;
         D_SHIFT=MAP1[m];
         swap(min);
         swap(hour);
         check_sw();
         check_sw();
         check_sw();
         check_sw();
         check_sw();
         //delay_ms(500);
         if (fs==0)
            output_high(colon);
            //delay_ms(500);
            if (fs==1)
               output_high(colon);
               D_SHIFT=0x00;
               D_SHIFT=0x00;
               m=hour & 0x0F;
               D_SHIFT=MAP1[m];
               swap(hour);
               m=hour & 0x03;
               D_SHIFT=MAP1[m];
               //delay_ms(500);
               output_high(colon);
               m=min & 0x0F;
               D_SHIFT=MAP2[m];
               swap(min);
               m=min & 0x07;
               D_SHIFT=MAP2[m];
               D_SHIFT=0x00;
               D_SHIFT=0x00;
               //delay_ms(500);
         check_sw();
         check_sw();
         check_sw();
         check_sw();
         check_sw();
#int_EXT
void EXT_isr()
   fs_flag++;
   if (fs_flag>=3) fs_flag=0;
// main program start here
byte u;
   delay_ms(5);
   port_b_pullups(true);
   output_low(EXP_OUT_CLEAR);
   delay_us(10);
   output_high(EXP_OUT_CLEAR);
   for(RES=0;RES<80;RES++)
   init_ds1307();
   u=read_ds1307(0);
   sec=u & 0x7F;// enable RTC
   write_ds1307(0,sec);   // set second to 00 and enable clock(bit7=0)
   fs_flag=0;
   ext_int_edge(H_TO_L);      // init interrupt triggering for button press
   enable_interrupts(INT_EXT);
   while(true)
      disable_interrupts(INT_EXT);
      if (fs_flag==0)
         show_temp();
      for (u=0;u<20;u++)
         show_time(fs_flag);
} //end of main program
PostPosted: Mon Sep 29, 2008 2:56 pm     Reply with quote
Make a test program that tests the one thing that you want to look at.
Make the program be as simple as possible. Example:
This program will blink the "colon" LED once per second.
#include <16F628.h>
#fuses XT, NOWDT, NOPROTECT, PUT, BROWNOUT, NOLVP
#define COLON  PIN_B4
   output_high(COLON);
   output_low(COLON);
Aurbo
PostPosted: Mon Sep 29, 2008 3:54 pm     Reply with quote
Thanks PCM
I ran a test program and B4 was still non-functional.
Removed the Transistor, and it worked after re-wiring that section.
Replaced the transistor with its opposite counterpart, swapping the NPN for a PNP and its now working.
The circuit component was identified incorrectly on the schematic.
My next step is to get the DS1307 to count DOWN instead of UP.
