Latch register for i/o ports
Jeff
PostPosted: Sat Sep 27, 2008 11:25 am     Reply with quote
Am using PCWH 4.079.
Target is PIC18F252.
Is it possible to read the i/o port latch registers, rather than the pins themselves, using C syntax?
PostPosted: Sat Sep 27, 2008 11:59 am     Reply with quote
There is no CCS function to read the latch registers. But you can use
a #byte statement to declare the register addresses, and then read
them directly, in code. Example:
#include <18F452.H>
#byte LATA = 0xF89
#byte LATB = 0xF8A
#byte LATC = 0xF8B
#byte LATD = 0xF8C
#byte LATE = 0xF8D
int8 value;
value = LATC;  // Read the latch register for Port C
The register addresses come from this section of the PIC data sheet:
TABLE 4-1: SPECIAL FUNCTION REGISTER MAP
