robin171
hardware uart does not receive all the characters |
Posted: Fri Sep 26, 2008 9:02 am |
I have a problem with the hardware uart of the PIC16F877A. The UART is connected to a powerline modem (ST7538).
The problem is that I only receive the last characters of the string. I send a string of about 20 characters, the first 10 are not received. I checked the RX pin of the PIC with a scope. The characters I use the #INT_rda interrupt to receive the characters.
here is my interrupt routine:
Code: | #int_RDA
void RDA_isr()
byte data = 0;
if(kbhit(COM1))
data = getc(COM1);
if(data)
fputc(data,COM2);
write_buffer((buf_t *)&rcv_buffer,data);
COM2 is a software UART. write_buffer is a function which puts the data in my buffer and checks for control characters. Here is the function:
Code: | boolean write_buffer(buf_t *buffer, byte data)
if(!buffer->full)
buffer->data[buffer->wr_idx] = data;
switch(data)
case '$':
buffer->rcvd_dollar = true;
buffer->dollar_position = buffer->wr_idx;
case '*':
buffer->rcvd_star = true;
buffer->star_position = buffer->wr_idx;
case '\n':
buffer->rcvd_nl = true;
buffer->nl_position = buffer->wr_idx;
default:
buffer->wr_idx++;
if(buffer->wr_idx >= RCV_BUF_SIZE)
buffer->full = true;
return true;
} else {
return false;
I use the following statement to configure the UART:
Code: | #use rs232(baud=600,UART1,stream=COM1,errors) |
Posted: Fri Sep 26, 2008 11:26 am |
Do some tests. Comment out the fputc() for the software UART, inside
the INT_RDA isr. Dump the buffer after you've sent a string.
Did you get it all, this time ? If so, the problem is in the fputc() inside
the isr. What's the baud rate for the soft UART ? You didn't post the
#use rs232() statement for that one. |
