PIC RS232 Routine "stops" after first loop.
Steve_Kos
PostPosted: Wed Sep 24, 2008 12:29 pm     Reply with quote
All,
I have been searching the forums for an answer to my simple
question, but nothing has worked yet. All want to do is read the
RS232 from Hyperterminal (1 character) using a PIC16F877A
(running on 4MHz) and save it and re-display it out the serial port.
Sounds easy, not sure why I can't get it to work. This code will work once and then stop working, any suggestions on getting this to work in a loop? Basic code is below:
      set_tris_a(0xFF);                            // Set PORTA to all INPUTS.
      set_tris_b(0x00);                            // Set PORTB to all OUTPUTS.
      set_tris_c(0x00);                            // Set PORTC to all OUTPUTS.
      set_tris_d(0xFF);                            // Set PORTD to all INPUTS.
      set_tris_e(0x00);                            // Set PORTE to all OUTPUTS.
      setup_adc_ports(AN0_AN1_AN3);
      setup_spi(FALSE);
      setup_counters(RTCC_INTERNAL,RTCC_DIV_2);
      setup_timer_1(T1_DISABLED);
      setup_vref(FALSE);
      output_b(0x00);                        // Set all port B I/O low.
      do
            rx_flag = kbhit();
            if (rx_flag == 1)
               data_in = getc();
               if ((data_in == 'v') || (data_in =='V'))
                  printf("VEH\n\r");
                  delay_us(10);
               if ((data_in == 'b') || (data_in =='B'))
                  printf("BATT\n\r");
                  delay_us(10);
               if ((data_in == 's') || (data_in =='S'))
                  printf("SHUTDOWN\n\r");
                  delay_us(10);
         while (test_loop == 1);
I checked to make sure the data is on the PIC lines.
Is it something simple or am I completely lost?
Thanks,
Steve
PostPosted: Wed Sep 24, 2008 12:33 pm     Reply with quote
You're setting the incorrect TRIS for the hardware UART's receive pin
(pin C7). You have set it to an output. My advice:
Don't set the TRIS. With CCS, you don't need to. The default mode of
the compiler is "Standard i/o" mode. In that mode, the compiler
automatically inserts code to setup the correct TRIS for you, provided
that you use CCS built-in functions, and CCS library routines.
It's absolutely best for newbies to let the compiler handle the TRIS.
Steve_Kos
PostPosted: Wed Sep 24, 2008 12:44 pm     Reply with quote
Geeez, thanks!
Totally missed that.
Thanks again!
Steve
SherpaDoug
PostPosted: Wed Sep 24, 2008 12:45 pm     Reply with quote
Where does test_loop come from? What is its type and value? Show us your includes and declarations including your use_rs232 statement. Also the PIC type and compiler version are sometimes relevant.
