johnnyD Guest
USB HID transmit problem |
Posted: Tue Sep 23, 2008 2:52 pm |
Hello ya'll!
I have modified the ex_usb_hid example. I can receive up to 64 bytes from a PC with no problem. Where I am getting stuck is trying to transmit x number of bytes to the PC. The problem is in the TX report count in the HID descriptor.
It works great if I set the TX report count to 5 in my HID descriptor and output 5 bytes, then the PC is able to read the data.
if I set the TX report count say to 10 and send out 9 bytes the PC doesn't read the data
is there any way to be able to transmit x number bytes that the PC can read?
#include <18F2550.h>
#device PASS_STRINGS=IN_RAM
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN
#use delay(clock=48000000)
#define USB_HID_DEVICE TRUE
#define USB_EP1_TX_ENABLE USB_ENABLE_INTERRUPT
#define USB_EP1_TX_SIZE 64
#define USB_EP1_RX_ENABLE USB_ENABLE_INTERRUPT
#define USB_EP1_RX_SIZE 64
#include <pic18_usb.h>
#include <usb_desc_hid.h>
#include <usb.c>
int in_data[64]={0};
int out_data[5]={0x41,0x42,0x43,0x44,0x45};
int1 ready=false;
usb_init();
while (TRUE)
usb_task();
if (usb_enumerated())
usb_put_packet(1, out_data, 5, USB_DTS_TOGGLE);
//while(usb_kbhit(1))
// usb_get_packet(1,in_data,64);
//ready=true;
// if(ready)
// printf("%s\r",in_data);
// ready=false;
Here is my descriptor code
const char USB_CLASS_SPECIFIC_DESC[] = {
6, 0, 255, // Usage Page = Vendor Defined
9, 1, // Usage = IO device
0xa1, 1, // Collection = Application
0x19, 1, // Usage minimum
0x29, 8, // Usage maximum
0x15, 0x80, // Logical minimum (-128)
0x25, 0x7F, // Logical maximum (127)
0x75, 8, // Report size = 8 (bits)
0x95, 5, // TX report count
0x81, 2, // Input (Data, Var, Abs)
0x95, 63, // RX report count = 64 bits
0x91, 2, // Output (Data, Var, Abs)
0xC0 // End Collection
Dave_Mustaine Guest
Posted: Tue Sep 23, 2008 4:06 pm |
Give this a try: The key is your data lengths must all match. The remainder of your packet will be all zeros but you can always parse them!
Good Luck
#define USB_EP1_TX_SIZE 32
#define USB_EP1_RX_SIZE 32
#include <usb.c>
#include <string.h>
int in_data[32]={0}; // Set array to zero
int out_data[32]={0}; // Set array to zero
int1 ready=false;
strcpy(out_data,"HELLO THERE!");
usb_init();
while (TRUE)
usb_task();
while(usb_kbhit(1))
usb_get_packet(1,in_data,31);
ready=true;
if(ready)
ready=false;
usb_put_packet(1, out_data, 31, USB_DTS_TOGGLE);
Now set your descriptor for the following
0x95, 31, // TX report count = 32 bits
0x95, 31, // RX report count = 32 bits
