Motor control PWM working yet in PCD ?
billvon
PostPosted: Thu Sep 11, 2008 4:27 pm     Reply with quote
I tried using the PWM setup commands - setup_power_pwm(), setup_power_pwm_pins() etc - but I get a :
Error 12 "dspic30_test.c" Line 72(21,22): Undefined identifier -- setup_power_pwm_pins
when I try it. (Device is dsPIC30F2020.) Does the 4.079 compiler support the power PWM module?
--bill von
Malkav
PostPosted: Mon Sep 22, 2008 11:34 am     Reply with quote
Maybe you can have a look in your .h file. If your function does not appear in it, it is because your PIC cannot support this function. And if it does not appear but you PIC can support it, you can have a little fun with manipulating registers.
I hope it can help.
