16f505 wake pullup
16f505 wake pullup
PostPosted: Mon Sep 22, 2008 7:35 am     Reply with quote
I'm trying to write a code based on pull up function of the 1f505.
MCLR not used, NOMCLR I mean.
I added
 port_b_pullups(TRUE); line
But compiler says "undefine identifier" for that line.
Also there is a little cosmetic bug in wizard
Although 16F505 has A port, A port pull up option appear in I/O section of the wizard.
thank you for your time.
Regards
PostPosted: Mon Sep 22, 2008 7:36 am     Reply with quote
Although 16F505 has NO A port, A port pull up option appear in I/O section of the wizard.
dyeatman
PostPosted: Mon Sep 22, 2008 1:48 pm     Reply with quote
You need to send CCS a note on this so it can be fixed in a future version..
support@ccsinfo.com
