PCD problems on reading port_B .. HELP PLEASE!
ik1wvq
PostPosted: Mon Sep 15, 2008 6:18 am     Reply with quote
PCD 4.079
3FJ128GP706
PROBLEM:
I try to read the PORTB ( whole with "input_b()" or single pin with "input(pin_rb11) ")
The results is all zeroes.
This my trivial program:
#include <33FJ128GP706.h>
#type unsigned
#Fuses NOWRTB,NOBSS,NOPROTECT
#Fuses NOWRT,PR_PLL,XT,NOCKSFSM
#Fuses NOOSCIO,NOWDT,NOWINDIS,WPRES128
#Fuses PUT128
#Fuses NODEBUG,NOCOE,NOJTAG
#define  LED_ROSSO PIN_B10
#word PLLFBD=0x746
#word CLKDIV=0x744
#use delay(clock=77414400, restart_wdt)
#use rs232(BRGH1oK,baud=9600,UART2, ERRORS,RESTART_WDT)
        PLLFBD=84;                      // M=75
        CLKDIV=0b0000000000000000;      // N1=2  N2=2
        delay_ms(50);
        output_high(LED_ROSSO);
        gira:
        restart_wdt();
        printf("\rRB->%lX  - ",input_b());
        printf("RG->%lX  - ",input_g());
        printf("RF->%lX",input_f());
        output_toggle(LED_ROSSO);
        goto gira;
The OUTPUT is:
"RB->0000 - RG->010E - RF->005E"
RG and RF follow the state of the inputs, RB is ALWAYS ZERO ..
What happens ???
Thanks in advance
Regards
Mauro
glap
PostPosted: Mon Sep 15, 2008 7:39 am     Reply with quote
Try to set the input port in digital mode (setup_adc_ports).
Bye
Gaetano
PostPosted: Tue Sep 16, 2008 1:36 am     Reply with quote
thanks anyway , but still dont work ..
ragards
ik1wvq
PostPosted: Tue Sep 16, 2008 1:38 am     Reply with quote
ragards
ik1wvq
PostPosted: Fri Sep 19, 2008 3:50 am     Reply with quote
I found myself the solution!
The chip 33FJ128GP706 has TWO analog_to_digital modules, and then, we MUST declare:
setup_adc_ports(no_analogs); // useless, because the compiler produces itself the relative code
setup_adc_ports2(NO_ANALOGS); // this line mandatory
Putting this lines the portb work fine!
I write this to CCS:
This matter (two analog modules) is unclear in the microchip manual, and also in your manual.
Please explain this problem to all other developers.
I found this by ten trials.
Mauro
