Were somebody working with Wiznet810mj TCP modul? Help me
evox
PostPosted: Fri Sep 12, 2008 2:58 am     Reply with quote
I attempt work with Wiznet810mj via SPI but I can't make communication, I
did all as written in datasheet but I can't write or read some register. If some
worked with this module can write sample code for write and read some register pls I crazed with it ?
Crying or Very sad
PostPosted: Fri Sep 12, 2008 2:37 pm     Reply with quote
Use Google. I easily found these results:
Here's some CCS source code:
http://bbs.circuitcellar.com/phpBB2/viewtopic.php?t=3468
This page has Microchip C18 compiler source code for the Wiz810mj:
http://www.circuitcellar.com/wiznet/winners/001166.html
Here is a tip on how to find CCS source code with Google:
Type in the part number of the chip that you want to use, and
also type in the name of a common CCS function that is unique
to the CCS compiler. Example:
Wiz810mj output_low
To find any C source code, type in the name of the chip and some
common data types that are likely to appear in any C program.
Example:
Wiz810mj int char
