Spot the error (should be easy)
CombatWombat
PostPosted: Fri Sep 12, 2008 6:49 pm     Reply with quote
I am trying to compile a very (very) simple program to learn the C (PCM V4) compiler. I know a bit of assembly using MPLAB already.
I am using a PIC16F690 on the Pickit2 low pin count demo board and using a Pickit2 for programming.
When I flash the chip with a program written in assembly, it works as expected (lights are flashing).
When I compile and flash the following program, my light stays on solid.
#include "D:\Projects\PIC\test2\test2.h"
   setup_adc(ADC_OFF);
   setup_spi(FALSE);
   setup_timer_1(T1_DISABLED);
   setup_oscillator(False);
   set_tris_c(0x00);
   output_high(PIN_C0);
   output_low(PIN_C0);
The header (compiler generated) looks like so,
#include <16F690.h>
#device adc=8
#FUSES INTRC                    //Internal RC Osc
#FUSES NOMCLR                   //Master Clear pin used for I/O
#FUSES FCMEN                    //Fail-safe clock monitor enabled
I thought maybe the WDT or brownout was tripping, so I turned those off. Once programmed the LED on port C0 turns on and stays on.
Ideas? Im running out. Are there instructions for loading a C program into MPLAB to use the simulator? I have not found them.
Thank you.
PostPosted: Fri Sep 12, 2008 8:03 pm     Reply with quote
See this test program:
http://www.ccsinfo.com/forum/viewtopic.php?t=34785&start=3
jfarkas
Datasheet
PostPosted: Sat Sep 13, 2008 3:52 am     Reply with quote
This could be problem....
#use delay(clock=20000000) ???????????
Gerhard
PostPosted: Sat Sep 13, 2008 8:26 am     Reply with quote
The internal oscilator on that pic is running at 4M. Just change that line
To
#use delay(clock=4M)
