Problem with pointers PIC24FJ128GA010
cahry
PostPosted: Mon Sep 15, 2008 8:16 am     Reply with quote
I am using pic24fj128ga010 controller and CCS compiler v 4.078.
I am getting errors for the following code.
        int (*temp)[2];        /* pointer to an array */
I am getting the following errors for the declaration of 'temp'
1. Expecting a (
2. Expecting declaration.
What can be the problem?
Does ccs support pointers to arrays?
PostPosted: Mon Sep 15, 2008 9:36 am     Reply with quote
I didn't check particularly, but following general C syntax a simple int pointer should do. There is no need to supply an array size with the definition, if you increase the pointer, it addresses the next array element.
