Were somebody working with Wiznet810mj TCP modul? Help me
Posted: Fri Sep 12, 2008 2:58 am
I attempt work with Wiznet810mj via SPI but I can't make communication, I
did all as written in datasheet but I can't write or read some register. If some
worked with this module can write sample code for write and read some register pls I crazed with it ?
Here is a tip on how to find CCS source code with Google:
Type in the part number of the chip that you want to use, and
also type in the name of a common CCS function that is unique
to the CCS compiler. Example:
Wiz810mj output_low
To find any C source code, type in the name of the chip and some
common data types that are likely to appear in any C program.
Example:
