getc() and kbhit()
boulder
getc() and kbhit()
PostPosted: Tue Sep 09, 2008 4:50 pm     Reply with quote
From my LST file, I realize that getc() includes the function of kbhit(), but why do many people like to use kbhit() before using getc() in their? Is this because their compiler is different from mine? I am using PCM.
....................       while(!kbhit());
0033:  BTFSS  PIR1.RCIF
0034:  GOTO   033
....................       data = getc();
0035:  BTFSS  PIR1.RCIF
0036:  GOTO   035
0037:  MOVF   RCREG,W
0038:  MOVWF  data
Thanks.
PostPosted: Tue Sep 09, 2008 5:07 pm     Reply with quote
It's difficult to search for that line with kbhit() in it, to see how many
times it's used that way. The only CCS files that use it in that way are:
c:\program files\picc\examples\ex_tgetc.c
c:\program files\picc\examples\ex_tgetc2.c
Those files do it because they want to wait for a key stroke, but they
don't want to get the character at that point. They want another routine
to get it. (ie., to remove the char from the UART).
FvM
PostPosted: Tue Sep 09, 2008 11:28 pm     Reply with quote
In the sequence
while (!kbhit());
xx = getc();
the first line is simply superfluous and can be omitted without changing the code's behaviour.
The said two examples are different in this regard. In ex_tgetc.c other conditions are evaluated, here the initial wait is probably meaningful.
In contrast, in ex_tgetc2.c, the initial wait doesn't serve a purpose and the example is misleading so far.
while(!kbhit());
do
  value=getc();
  if (value)
    putc(value);
} while (RS232_ERRORS);
