Ext Interrupt only triggered on port B pin 0
Ranfo
PostPosted: Mon Sep 08, 2008 11:50 am     Reply with quote
I need an external interrupt that is triggered by a change on ANY pins of port b. Here is the code that works with pin 0 and no others. I have tried everything I can think of. Am I missing something simple?
#include <16F887.h>   // PIC Device Header
#device ADC=8 PASS_STRINGS=IN_RAM // HIGH_INTS=TRUE
#include <stdlib.h>
// --- FUSES ------------------------------------------------
#FUSES LP         // Use low power osc
#FUSES INTRC_IO   // Internal RC Osc
#FUSES NOWDT      // No Watch Dog Timer
#fuses NODEBUG    // No Debug mode for ICD
#fuses PROTECT    // Code protected from reading
#fuses NOWRT      // Program memory not write protected
#fuses NOLVP      // No low voltage prgming
#fuses NOCPD      // No EE protection
#fuses NOBROWNOUT // No brownout reset
#use delay( clock=31000 )
// === Global Variables ===
int8  gSleepcounter = 0;
int1  gIsSleeping = 0;
// === TIMER 2 ===================================
#INT_TIMER2  // Service Timer 2
void isr_timer2(void) {
   gSleepcounter++;
   if (gSleepcounter > 10) {
      gIsSleeping = 1;
// === external interrupt  =============
#INT_EXT
void ext_isr() {
   gIsSleeping   = 0;
   gSleepcounter = 0;
// === Initialize =============================
void initialize() {
   setup_oscillator(OSC_31KHZ);
   setup_timer_2(T2_DIV_BY_16, 255, 1);     // Timer 2 (DIV_BY, Period, Post)
   enable_interrupts(INT_TIMER2);           // Enable Timer 2 Interrupt
   ext_int_edge(H_TO_L);          // init interrupt triggering for button press
   enable_interrupts(INT_EXT);    // turn on interrupts1
   enable_interrupts(GLOBAL);     // Enable Interrupts Global
   port_b_pullups(0x1F);          // Pullups on Keyboard Input Port
// === main ============================
   initialize();
   output_high(PIN_A0);
   output_e(0x00);
   output_c(0x00);
      if (!gIsSleeping)
      {                            // Awake
         output_high(PIN_A0);      // turn on radio
      {                            // Asleep
         output_low(PIN_A0);       // turn off radio
      output_d(input_b());         // Send Data
RLScott
Re: Ext Interrupt only triggered on port B pin 0
PostPosted: Mon Sep 08, 2008 12:51 pm     Reply with quote
What you want is "Interrupt on Change". That is a different interrupt from INT_EXT. Also interrupt on change causes an interrupt when an enabled Port B pin changes in either direction. The external interrupt on RB0 only works in one direction.
Robert Scott
Real-Time Specialties
Embedded Systems Consulting
Ranfo
PostPosted: Mon Sep 08, 2008 12:58 pm     Reply with quote
Thank you. Can you show me where I can find information on this?
meereck
PostPosted: Mon Sep 08, 2008 1:05 pm     Reply with quote
simply:
#int_RB
void RB_isr()
   int8 current;
   static int8 last=0;
   current=input_b();
   if ((!bit_test(current,PIN_B0))&&(bit_test(last,PIN_B0))) {
// we have falling edge on B0
   last=current;
and enable global and RB interrupts:
enable_interrupts(INT_RB);
Ranfo
PostPosted: Mon Sep 08, 2008 1:17 pm     Reply with quote
If I replace INT_EXT with INT_RB then the interrupt never triggers even on pin 0. I am still missing something.
Ranfo
PostPosted: Mon Sep 08, 2008 1:28 pm     Reply with quote
OK, seems to be working now. Thank you all. Posting changes so others can see:
// #INT_EXT
#INT_RB
void ext_isr() {
   int8 n;
   n = input_b();
   gIsSleeping   = 0;
   gSleepcounter = 0;
void initialize() {
   enable_interrupts(INT_RB0);
   enable_interrupts(INT_RB1);
   enable_interrupts(INT_RB2);
   enable_interrupts(INT_RB3);
   enable_interrupts(INT_RB4);
   port_b_pullups(0x1F);          // Pullups on Keyuboard Input Port
